Results 1 to 20 of 20
Thread: Oil pressure issues
    Nov 2016
    Boring Oregon
    9
    Oil pressure issues
    I recently bought a 1959 Lark VIII that a previous owner installed an oil pressure gauge in and that its readings concern me. When cold it indicates 20-25psi idling but quickly falls to about 5psi when warmed up, I should add that at no time has the oil light come on and it does work. Down the road at 55 warm is 20psi. I was told by the owner who is my neighbor and trustworthy that the engine was completely rebuilt about 10 years ago but has had little use in that time with less than 5k miles accumulated. My first thought was those pressures seemed low but perhaps it was a defective gauge, which I plan on replacing. But if those are the actual pressures my next thought was the oil pump. In doing some searching I find that only the oil pump gears are available and not a complete pump assembly. Does anyone know where I can buy a complete new pump? Also any other thoughts are appreciated, thank you.
    Gerry
    10,023
    There are knowledgeable folks here with much more credibility and experience than I. So, be patient, and perhaps some will add information helpful. In the mean time, I'll ad a few comments. "Rebuilt," unless you witnessed it, is always a suspect term. To some, replace bearings, and/or rings, is considered rebuilt. How much honing, oversize, undersize, valves, stems, rockers, cam bearings, line boring, etc. etc., and so on...?
    Is there an oil filter with a missing flow restrictor fitting? And as always, (I've never been so lucky), is there an incorrect oil gauge. In the case of the cars with the simple oil (idiot) light, I've heard of them giving you an OK indication with less than ten PSI of oil pressure. Honestly, I think the Studebaker engines are sturdy enough to allow a lower oil pressure than many makes, as long as there's sufficient oil "flow." Of course, PSI & FLOW are related, and I don't know the mathematical specs.
    You have not mentioned (unless I failed to comprehend) oil pressures on the road, underway. I have had engines that had fair oil pressure, at speed, and showing little when idling, that ran great for years. On our Studebaker engines, there's the ever present, often overlooked, oil pressure relief valve. If neglected, it can suffer from restricted movement, and affect pressure reading.
    Do the easy things first, to verify the readings. Install a good gauge to verify pressure, and service the oil relief valve. Do not stretch the spring. If need be, replace it. If it is truly low oil pressure, and the flow is too low, unless I'm wrong, oil through the engine returns over (and lubricates) the timing gears. Too little flow there, and it can cause premature failure of the fiber cam gear.
    As for oil pumps, unless the engine has really been neglected, a lot of grit, metal debris, or hard carbon deposits pumped through it, not likely to be worn. After all, it is constantly bathed in oil. A good place to check is the front main & rod bearings. Being softer metal, those components getting the first crack of pressurized oil, will have small particles of harder materiel embedded in them. Hope this helps, & wait for others to either verify or endorse my (suspect) comments.
    Commander Member sailingadventure's Avatar
    Aug 2012
    Greensboro, NC
    85
    And there`s always the possibility that the last guy left out the oil gallery plug below the distributor.
    Nov 2016
    Boring Oregon
    9
    I may not have made it clear but in my original post I put at 55 with the engine fully warm it pumps right at 20psi indicated on the gauge. Thank you to both for answering and any more suggestions are welcome and appreciated. I have a local Studebaker owner that seems to be quite knowledgeable looking at it and he told me that he has already replaced the oil pressure relief spring with no change and he tells me that in his opinion wear does occur to the inside of the oil pump casing over time that just replacing the gears does not address hence his suggestion too look for a entirely new pump.
    Gerry
    Gilbert, AZ, USA.
    862
    The oil pump is the first thing to get oil and the last thing to run out. Oil pump wear isn't normally an issue on the stude v8. Camshaft bearing wear, rod, and main bearing wear are typically the problem with low oil pressure. Also excessive wear on the rocker arm assemblies will also add to the low oil pressure woes. The missing oil galley plug in the distributor tower area is a common mistake, not sure what the oil pressure would be without that plug, low to none I'm assuming.
    Studebaker engines can survive on low oil pressure and while it makes me a bit concerned at these levels the motor will survive for quite some time with these pressures. Here is the approach I would take.
    1. install a good known mechanical gauge and check confirm pressure.
    2. remove distributor and inspect for missing oil galley plug
    3. if partial flow filter block then temporarily plug pressure port at block. If oil pressure increases inspect oil filter assembly for restrictor fitting.
    4.run 50 weight racing oil
    5. IF still concerned at this point, IMHO you'll need a quality rebuild.
    Quote Originally Posted by gerry r View Post
    Gerry
    Russ Shop Foreman \"Rusty Nut Garage\"
    53 2R6 289 5SpdOD (driver)
    57 SH (project)
    60 Lark VIII 2dr sd (driver)
    Austin, Texas
    885
    Malfunctioning pressure relief valve spring?
    Great Falls VA
    3,256
    Change the oil to a good grade 20-40w (Valvoline?) or even a straight 30w and check it out again.
    64 GT Hawk (K7)
    1970 Avanti (R3)
    13,882
    Quote Originally Posted by sailingadventure View Post
    It's my understanding that, under any idle situation, this would result in a reading of zero pressure.
    13,882
    ... wear does occur to the inside of the oil pump casing over time that just replacing the gears does not address hence his suggestion too look for a entirely new pump.
    I've also found, at least in the six cylinder, simply honing the oil pump cover plate will significantly improve the pressure.
    Oct 2009
    Eastern NC
    1,111
    When my engine was rebuilt with the plug left out, it would start cold and idle at about 20 psi and fall below 5 psi when it came up to full temp. Mine never dropped all the way to 0.
    Wayne
    "Trying to shed my CASO ways"
    7,876
    The above is for true. When I'm asked about a rebuild, I know CASOs will always comparision-shop and I give them a list of operations and parts to make sure they're comparing apples.
    Again, for true. New gears and shafts, with the end play properly set, usually are worth the money.
    May 2012
    Oklahoma City
    594
    Before checking out anything else, I would screw in a good temporary mechanical oil pressure gauge. You MAY not even have an issue.
    If it confirms the low oil pressure, then pursue the items set out above, starting with the easiest and least expensive. It will cost you nothing to pull the distributor and confirm the presence of the plug as set out in post number 3.
    Nov 2016
    Boring Oregon
    9
    These readings were done after I changed to Delo straight 30
    1,218
    End play properly set sometimes means using a surface plate to "Shave" the oil pump body a few thousandths to get clearances right,effort well spent. Luck Doofus
    4,390
    Gerry -
    The Stude V-8 tends to run a little lower pressure thAn most engines.
    As has been said, you can "blueprint" the oil pump to gain some pressure.
    Another loss location is the various bearings, including the cam bearings. Excessive connecting rod side clearance will drop pressure from the system also.
    So yea, there's a LOT of locations to look. If the engine rebuild wasn't done with a careful hand...!?
    A way of upping the pressure, but be aware...it does NOT "fix" the low pressure problem, is to use thicker oil. It just has a harder time going thru the system, but again, does not fix, just disguises the basic problem.
    Also a fact to think about. This isn't so much apples to oranges as you might think, but many (non-supercharged) drag racers run a very low engine oil pressure (and a minimum trans. pressure). Why, releases more power to the driveshaft. Pumps take power to drive them. I have a friend that runs a small inch, big block Chrysler in a dragster that runs only 50psi at...10,500 rpm at the finish line at over 173 mph.
    Right behind you
    1,728
    Gerry
    First off, before you do anything else, check the actual pressure with a known good gauge.
    Secondly, people get far too excited about oil pressure. Engines require oil flow more than they require oil pressure. If oil is being supplied everywhere it needs to be, pressure, which is measured before the oil gets anywhere it needs to be, is almost meaningless. Maybe counter productive. You could have 50 psi at the gauge and 2 psi at the rod and main bearings. And, of course, the oil pressure at the cam lobes and valve stems is always zero. And that's not a problem. Back in the good old days, folks thought they needed to run 30 wt oil because it gave better gauge pressures than 20 wt. But remember, if you use thicker oil to get higher pressure out of the oil pump it always means lower flow where the oil is needed.
    Nowadays we think 5W30 or 0W40 is better because it flows more oil to where it is needed when the oil is cold and thick.
    When the Lotus V8 came out, the oil pressure gauge was marked L-N-H because the normal oil pressure for that engine was 5 psi hot and people would have panicked.
    You could dump a few bottles of STP in it. The pressure at the gauge will come up, and the amount of oil delivered to the bearings and elsewhere will be less. IMO, those viscosity increasers, polyisobutylene, like STP and others did exactly the opposite of what was wanted. They increased pump pressures, and reduced oil flow downstream where it was needed.
    Or you could run 5W30, lower pressure at the gauge, but more oil everywhere it's needed.
    Those old GMC pushrod sixes ran 2-3 psi at hot idle, and lasted a long time.
    With no symptoms of low pressure - like bearing knock, I wouldn't get very excited. Does it run well without any unexpected noises? If so, keep calm.
    , , Canada.
    864
    Had a 55 Speedster once that ran 30-40 psi at speed & 5-10 at idle,I drove it for 5 yrs. like that & fellow I sold it to has been driving it for 10 yrs. like so with no issues.If I were you I would just drive it unless you want to spend a pile of $$$ to fix what doesn't need fixing !
    3,625
    once again, thoughts put forth (no one in particular) are a mix of old oil logic and days of daily driving.... who drives these 60+ year old cars 10K miles a year ? very, very, few. The low oil pressures mentioned for the Stude (or any other engine either) represent 1000-1500 driving miles a year. With 5 lbs @ idle and 25lbs down the road in an engine looking to 1000 miles a year, and newer oils.... who in their right mind would fool around building one excepting for a future sale ????
    10,023
    .... who in their right mind????....
    Not to discount the value of your post...but the portion I chose to concentrate on, is probably the most often thought expressed toward any of us cherishing and clinging to our Studebaker(s)!
    Nov 2016
    Boring Oregon
    9
    Thank you all. The engine sounds fine both at idle cold or warm, and the same for going down the road. I am going to replace the gauge and sending unit and see what that shows.
