Does anyone know of a good LED replacement for my 1950 Champion 1158 tail and stop light bulbs?
Here is an LED to replace the 1154 bulbs, which have staggered pins. The 1158 has both pins on the same level. I could buy these and file off the high lock pin, and it would probably work, but I'd prefer the correct bulb.
The reason for trying the LED is to see if the lower amp draw would make the brake light switch last longer. I'd rather go this route than add a relay to drop the load on the brake switch. Thanks, Tom
