I'm still plugging away on the 1957 Golden Hawk restoration. In a few months I will be moving to another state so I feel some urgency in getting the engine back onto the frame. So the next phase involves reattaching the torque converter and transmission to the block. It is amazing what you find when you break down an engine. When I originally removed the torque converter I noticed that 5 of the bolts attaching the flex plate to the converter were similar in appearance with a castellated (?) head. The 6th was different; the head was flat on the top and it was clear that someone had found a 3/8 24 bolt and cut it off to fit. It is shorter than the other 5 bolts. No lock washers present - OK I guess?
Can anyone with experience tell me what to do here. Little things have a way of impeding progress! I can't seem to find a replacement of the correct length or head configuration. From what I learned, the part number is G9409125. However I can't find this number in the parts book I have. It is 3/4" long but only 1/2" long from under the head to the end with 3/8 X 24 thread. Is there a source for correct bolts for Studebakers that one could go to and consistently find what they need for these specific applications? I don't want to have an odd size bolt or set up some slight weight differential in the process. Or maybe I shouldn't worry about it and cut off any bolt to fit?? Do I need lock washers or just torque them down to.....?
Thanks in advance for any help!
Jim
Jim
