Thread: what's the function of a horn relay ??????
    Jun 2005
    Atchison (on the Mo. River), Kansas 66002, USA.
    1,195
    I'm working on a '47 Champ sedan. One of the horns works, and one trys to work, by using direct hookup to the battery. Neither will work through the horn relay. I removed the cover on the horn relay and the points open and close and I filed the points. Why aren't horns hooked up directly to juice via a switch ?? What does the relay do ??? Is there any adjustment for the non working horn ?? or WD40 ?? or Electronic spray ?? Relay fix ??
    BRAD
    Arnold, Md., USA.
    15,728
    The relay allow you to control a large current with a smaller switch and horn wire. Without it, you need a heavy duty horn switch and heavy gage wire. If the relay clicks and the horn does does not work the relay is probably bad or you have a bad connection or wire.
    JDP/Maryland
    63 R2 SuperHawk (Caesar)
    spent to date $54664,75
    64 R2 GT (Sid)
    spent to date $62,439.30
    63 Lark 2 door
    51 Commander
    39 Coupe express
    39 Coupe express (rod)
    President Member mapman's Avatar
    moscow, id, USA.
    855
    In addition to what JDP said the horn relay uses a ground switch to activate the circuit. This keeps live voltage out of the steering column and simplifies the system. The relay prevents a dead short. If you have had your horn go off going around a corner you have experienced the problems with the wires inside a moving part (the steering tube and wheel). Often you find on old cars that the horn button was disconnected (and sometimes a seperate switch or button has been installed).
    Rob
    2,120
    For the same reason that starter current isn't run thru the ignition switch. That's why they used to have a button on the floor; it could be heavy duty enough to connect high amperage and still not burn out. Manufacturers would have to utilize a monstrous switch inside the steering wheel in order to not burn out; carrying enough voltage to activate a horn.
    5,254
    BRAD
    Brad, it was mentioned on the Forum the other day that the relay terminals are not marked. It could be that the terminals for the battery and the horn button are swapped. That would still allow the realy to click, but it wouldn't blow the horn. try swapping them, and see what happens. If that doesn't work, swap them back again.
    17,767
    http://tinyurl.com/yukj6y
    BRAD
    Feb 2007
    Las Vegas, NV, USA.
    891
    The best bet is to bench test it out of the car. Before hooking mine up, I took it out and applied 12V to various pairs of terminals. With an Ohm meter, I determined which terminal was connected to the "closed when energized" contact. Marked it for posterity!
    Las Vegas, NV
    '51 Champion Business Coupe G899965 10G-Q4-1434
  1. 'Delete' Function On The Forum
    By DEEPNHOCK in forum "Stove Huggers" the non-Studebaker Forum
    Last Post: 08-17-2009, 02:37 PM
  2. Horn relay help
    By Kdancy in forum Tech Talk
    Last Post: 08-09-2009, 06:57 AM
  3. Horn Relay
    By mjeansonne in forum Tech Talk
    Last Post: 01-31-2009, 06:13 PM
  4. 62 Lark 62S-Y4--Horn Relay
    By 4ever16 in forum Tech Talk
    Last Post: 10-25-2007, 08:43 PM
