I picked up my 1961 Lark VIII this weekend. It is now sitting in my garage and the mountain of parts that came with it are up in the attic. Landed Saturday and got it on four jack stands Sunday morning. Pulled the wheels off, drop the gas tank, and put some penetrating fluid down each cylinder. I put a wrench on the crank and it will turn over. The guy I got it from claims it runs and drives. The master brake cylinder was almost dry when I picked it up. I put some brake fluid in there to see if I could get enough pedal to move on and off the trailer without fear of running into something. Managed to get enough pedal. I see there is one wheel cylinder leaking pretty badly, but luckily there are four new ones in the mountain of parts...
I plan to clean out the gas tank (it is pretty clean inside (still had a little over two gallons of old gas in there when I dropped it down). I will flush it out, clean up the outside and paint it and have it ready to go back on. Tonight, I will blow some clean gas through the fuel line between the tank and the pump and see what it looks like. I will likely replace them, but they appear to be in good shape, so if they are clean, I might just leave them. Then it will be compression test, check for spark, new set of plugs and wires, and put the fuel system back together. Then I will see if I can get the engine to run.
The car is in exceptional condition. All four fenders were replaced before it went into storage and are rust free. I have a NOS left rear fender in the pile of parts, as well as a left front in good condition. There are two NOS doors in the pile (crazy to see doors that old that have never been on a car...) although the ones on the car are in good condition. They have a little rust (very little) along the bottoms, but it appears to be surface only (time will tell, but at least I have the two in my attic now if needed).
I am going back next weekend to pick up the stuff I couldn't get in the first run, including front and rear glass (mine is fine, but I am bringing both those back to go up in storage). I have one complete interior and another that is missing a couple of pieces. One is red, the other blue. The blue one is complete and the original from the car. Trim pieces in the pile are overwhelming... The trim on the car is complete except for one or two pieces, but the pile has enough trim to do two cars at least... I also have 5 bumpers (three front, two rear). Switches, quarter windows, intake manifolds, bell housings, steering columns, power steering setup, distributors, fuel pumps, wiper motors and linkages assembly, and the list goes on and on. I ended up taking everything he had in parts (my first thought was to pick through what I thought I might need, but I have the space for it, so I took it all). The car is virtually complete, so all the parts are just extras.
I will post some pics once I get settled down and have a chance to get it outside. Excited to work on this with my kids. They are excited too.
BTW:
1961 Lark
259cid V8
2 door
61V VIN
automatic
off white exterior
blue interior
BTW:
1961 Lark
259cid V8
2 door
61V VIN
automatic
off white exterior
blue interior
