The Saturday Night Special
Well progress is slow but thankfully picking up a little. Got all the finish body work done on hood. It's been blocked and primed again, and is ready for sanding and paint:
Same holds true for the trunk lid.
The top and the left side, all body work, primed, blocked, and primed. ready for sanding:
Will be moving to right side maybe tomorrow???
Thanks, guys. I have the right door finished with body work, blocking, and primer. Working on fitting the quarter on this side. I'll finish this quarter and then move to the last of the body work and primer. It includes finishing the area around windshield, the rocker panels and a few pieces of front sheetmetal. The fenders are ready to bolt on and then they have to be blocked and primed again. I am making a little progress.
Originally posted by Flashback View PostThanks, guys. I have the right door finished with body work, blocking, and primer. Working on fitting the quarter on this side. I'll finish this quarter and then move to the last of the body work and primer. It includes finishing the area around windshield, the rocker panels and a few pieces of front sheetmetal. The fenders are ready to bolt on and then they have to be blocked and primed again. I am making a little progress."In the heart of Arkansas."
Originally posted by rockinhawk View Post[ATTACH=CONFIG]60046[/ATTACH]Lookin' Good Tex. I picked up a 53 C myself recently. Maybe we can get a picture of them together someday. Neil
Well, I did finish the right quarter panel as well as getting the left door aligned correctly. It's hard to get these body panels where the fit is acceptable. Still working on right door alignment.
Starting to see a little progress. The right fender is sitting ready to start the front sheet metal alignment.
Bout finished the front lower air scoop with body work, on to priming and blocking.
Testing to see if I can add new photo:: Here goesLast edited by Flashback; 05-18-2018, 07:13 PM.
Great to see you are able to work on it again!!!!!HTIH (Hope The Info Helps)
Originally posted by Flashback View PostTaking up again, working on left door to finish alignment and have had to move the lower hinge in, a few months back. Now the shimming and alignment. Next finish the lower scoop.
[ATTACH=CONFIG]72818[/ATTACH]Jerry Forrester
Forrester's Chrome
Douglasville, Georgia
