First off, thanks to everyone that has helped me through things so far. It's been great. I have a similar post on here about deciphering my PO. I wanted to create this one so that the specifics were typed out and could be searched via the search tools. It might be helpful to someone else. ???
So far, I have found out the following from digging through the forums and the web:
Bob's Studebaker Resource Website - Studebaker Dealer Listing
DESTINATION 9 CAMDEN, ARK: I can't find the details of the old dealership, but the original owner's grandson said that it was Pryor's in Camden, Arkansas. He said he remembers because the dealership owner's wife was in politics and the son, David Pryor was later Governor, State Rep, and Senate. The web simply says that William Edgar Pryor was a dealership owner in Camden. I can't find info an the specifics though. I hit Bob's Studebaker Resource Website - Studebaker Dealer Listing but didn't see it on there.
SERIAL NUMBER G667433: This matches the serial number on the door plate.
ENGINE NO. 756433: The engine was replaced. More than likely it was replaced by a non-dealership mechanic since the old number was not stamped on the back engine flat-out. The engine number in this one is 6I6222.
BODY NO. 46311: This number matches the body tag on the firewall.
IGNITION KEY NO. 4249: I can't read a number off the key, but it operates the ignition and the doors, so I am assuming it is the original.
TRUNK KEY NO. 1337: This matches the trunk key I have.
I also have a glove box key not listed on the PO of S1260.
MODEL AND BODY TYPE 9G-W5 BUSH: I have been told this is the 1950 Champion Regal DeLuxe - 4 Door Sedan. (Please correct if wrong) This matches the body tag as well.
AUTOMATIC TRANSMISSION SERIAL NO. 5282: This matches the serial number listed on the transmission plate so I am assuming this is original.
PAINT NO. AND COLOR 2293 SURF: I am assuming this is the Surf Grey Enamel (As listed on the underside of the dash/glove box) but the numbers are different.
The current KNOWN equipment and trim are as follows:
- Ash trays - rear
- Assist straps - rear
- Automatic trunk light
- Stainless steel body sill mouldings
- Stainless steel door escutcheon plates
- Stainless steel door scuff panels
- Carpeted floor
- Stainless steel seat trim
- Rubber gravel pads
- Half-ring horn ring
- Leatherette and cloth doors
- Stainless steel window trim
- Two-piece windshield
Info I would like to complete my documentation on the car:
- HOW TO SHIP 4WK: Does anyone have a clue on 4WK or who that would be?
- ENGINE NO. 756433: Is there a way to find out what the original engine components were from the factory? The replacement engine is 6I6222. It is also -oil filter. I just want to attempt to go back to its original state as close as possible. I know the original family and would like to finish it and show them.
- PAINT NO. AND COLOR 2293 SURF: Does anyone have a clue what color this is? I have not been able to find a paint color match in 1950 paint colors. Also, is this the same as the tag inside of #8409 COOK'S W.V.R. SURF GREY ENAMEL?
- What is the color of the wheels that came on a car painted the SURF color?
- TRIM NO. 7595 EG CL-1: I have no idea about any of this. How can I find out what this means?
- MODEL AND BODY TYPE 9G-W5 BUSH: What is "BUSH"? I know it's a telegram shorthand code, but can't find anything on what it means.
- AUTOMATIC TRANSMISSION SERIAL NO. 5282: I know this is an automatic transmission, but I don't know if it is a 2-speed, 3-speed, overdrive, automatic drive transmission, etc... I found the following on the automatic drive transmission: First, it was air-cooled, so it did without costly, complex water-cooling. It also allowed push-starts if needed, did not "creep" the car forward from a stop if the driver released the brake, and included a hill-holder that prevented rolling down an incline at idle. Selecting Reverse at more than 10 mph automatically put the transmission in Neutral to prevent damage.
- HILL HOLDER X: Does this mean that it DOES have a hill holder? If so, I assume it is built into the transmission as described above since there isn't a pedal.
- The family had another key they gave me with this. It is also a YALE key with the code C888. It is brass. I don't know what it goes to though. Any ideas?
Anything else anyone wants to add. I am trying to sponge up all the info/knowledge I can on this thing.
