The starter quit working a short time ago. Not too far from home. I had a friend say."Hit it with a hammer at the same time as you hit the key." To my suprise it worked. I got it home and went out several times and it always worked. not now.
I have good lights. the solinoid clicks. no starter spin. I did clean all the contacts.
I went to the stude manuel and read about removing the starter.
questions 1) it says in the man. to remove the electrical conection first then the bolts that hold the starter.how? they are on top of the starter. do I do that last?
2) I got the bottom nut spinning off no problem.what do you use to get at the top one? I can get a wrench on it but not move the wrench. years ago I remember seeing a starter/generator wrench. a curved sort of thing. is that the little devil I am in need of? if not what.
3) lastly. I want to replace the wire from the solinoid to the starter. what would you suggest I use. do the venders sell a ready made one of the proper length or do I just make one. and what guage and type of wire. I have been told that welders wire (01?) is not the wire of choice. what did you use?
thanks for your wisdom.Rich
64 Daytona HT
64 Daytona HT
