Turbos are a simple way to force air into the carb, just like Studebaker, (No fuel injection or computers) did with the Paxton SC. Superchargers take HP to make more HP. Turbos use waste, (exhaust) to make free HP. Yes, there are safety measures, (waste gate), needed to limit boost and tuning to get them correct, just like any other performance add on. Any shop that sells/installs turbos can get you vast amounts of information or set a system up for you. Engines don't want to be high compression or need lumpy cams to get performance. When driving normal the turbo usually gains MPG also. Fuel injection and computers are NOT required. AIR FLOW VARIANCE is what makes carbs work. More air is sucked/forced in drawing more fuel with it. What part of that changes? I don't see a problem building an air box around a carb, Studebaker did it in the 1960's. There was a post in the last several months about a turbo being installed on a Studebaker flat head six with little done to the old, tired engine itself. This was his experiment. Doing very little to an old engine to see how the turbo would perform. As I remember he kept adding boost to see how far it would go before it blew and did finally blow up the old engine by pushing it to far. Had he kept it reasonable, it may still be running today. He was in the process of installing the turbo on another flat head.
Originally posted by BILT4ME
View Post
