Results 1 to 16 of 16
Thread: 50 Commander shocks
    Jul 2015
    Along the Mohawk
    107
    50 Commander shocks
    I was looking at the shop manual last night and noticed that the Champion and Commander suspensions are similar. Is it possible and or desirable ( at least from an availability \cost perspective) to convert the Commander to conventional shocks?
    4,875
    You would have to fabricate shock mounts. This is not an unknown in the automotive world. The 46-48 Fords came with lever action shocks and many were converted to airplane type shocks. J.C.Whitney used to sell the kits, which included the shock mounts.
    You just have to get the math/geometry right, especially around travel and angles. And you have to be able to weld and fabricate.
    Since 50 Commanders are relatively rare in the grand scheme of all the antique cars out there, there might not be a lot of information about this particular modification. If there is any information, this is the place to get it.
    Does anyone specialize in rebuilding the original knee action shocks for the 1950 Commander?
    President Member LeoH's Avatar
    Oct 2012
    Sun Valley, NV
    2,110
    Oh yeah. In looking for info on rebuilding these, I came across someone's article about what he did to rebuild his knee action shocks. He referenced this company for parts: http://www.classicautoshocks.com/
    Oct 2012
    Sun Valley, NV
    2,110
    Oct 2012
    Sun Valley, NV
    2,110
    Here's another operation referenced on the HAMB: http://nosimport.com/
    Aug 2009
    Midlothian, Texas, .
    225
    I have installed the front suspension from a 50 land cruiser parts car in my shop in my 50 champion. To install airplane shocks you will need the lower mounts that bolt to the lower control arm from a 50 champion and drill holes to mount them. There is a hole in the top of the frame for the shock. Also the trunnion nut behind the knee action shock will have to be replaced as it has no grease fitting. The hardest part is removing the spring to drill the holes.
    Barn Find
    1950 Champion
    Before I started
    Jim Berry
    Midlothian, TX
    Mar 2018
    Bakersfield California
    31
    I will be calling Five Points in Santa Ana tomorrow and will report my findings.
    I also have a 50 Commander and would like to convert over to a coil over spring setup.
    Question: Is the upper mount the same in both the Champion and Commander? If so, I only need to fabricate the lower mounting bracket??
    DT Holder
    1950 Commander
    327 small block with turbo 350 trans
    Bakersfield Ca.
    5,737
    Your old shocks may just be out of adjustment, or low on oil. You DO know that they are adjustable don't you? This is why we always say get the shop manual for your car FIRST, then spend (waste) money after.!
    Mar 2018
    31
    Well of course I did NOT know they were adjustable. (thanks) To my credit I did post here first.
    I did not see any information on this in the service manual and I have all of the manuals on order from Studebaker International. (on CD)
    I will look into adjusting them. They may very well be OUT of oil. Does anyone have a reference on this procedure???
    Note: I have owned this car for 4 days.
    I just checked my lube chart, and the 50 Commander has 51 places to lubricate, 39 of them being grease fittings.
    Mar 2018
    31
    Info: I called Five Points in Santa Ana and they do still refurb the Studebaker shocks for ~190 each.
    Sooo, adjust and oil you say.
    2,797
    If you need new shocks I have many N.O.S. units some back to 1939 and a few earlier , not all are available
    These are brand new in the original boxes for $95.00 each.
    Robert Kapteyn
    studebaker@mac.com
    Text to 815 212 2389
    Oct 2005
    St. Louis, Mo.
    1,629
    SI used to have a lot of the front ones in NOS condition
    Milt
    1961 Hawk 4-speed
    1967 Avanti
    1961 Lark 2 door
    1988 Avanti Convertible
    Member of SDC since 1973
    Nov 2013
    Goldendale WA
    186
    Place called Apple Hydraulics.com has add for lever Shocks and sleeving brake cyls in oldcarsweekly.com
    Aug 2009
    225
    I don't know if there is anything I have overlooked but I converted my 50 Land Cruiser to airplane shocks and it's driving just fine. Only parts I had to find was the two lower shock mounts in front. The Champion mounts fit with no mods or drilling. Also had to find upper mounting bolts from a Champion, the Land Cruiser even has holes in the frame in the correct position. I have not yet installed the front bushing but plan to soon. I left the old shocks in place with the linkage removed until I get the bushing. Kind of odd but the Land Cruiser has all the holes to do this, just need the bushing, lower front mounts and upper rear mounting bolts.
    Barn Find
    1950 Champion
    Before I started
    Jim Berry
    Midlothian, TX
