2 days and over 3 hours trying, but I finally got bolt #4, Death, the last of the 4 oil pan Bolts of the Apocalypse in tonight! #%*@ If I do have to remove the oil pan on this Commander Six, I'm drilling a hole on either side of the edge of the center flare of the crossmember so at least I have a straight shot access with the socket extension to the 4 bolts to remove and install.
SUCCESS! Finally
Thank you, and I only thought about leaving that one hole open after considering the option of dropping the pan again just to align the hole for that one bolt. That was what I was contemplating having to do before it went it after I removed the socket u-joint and tried it with another socket and no u-joint. Bastidge.
