On the 2R16 and 17 there is an adapter plate between the water pump and the block. There are 2 bolts holding the plate to the block, the lower of the bolts appears to go into an open cavity in the block. Should I add some sealer around the bolt when reinstalling it?
It didn't leak prior to my removing the plate and bolt, but I want to be sure it doesn't leak after I put it back in.
Thank you.
Thank you.
