I have a 2 speed axle truck with some dried crusty mud and old grease on the rear hubs, can I take a powerwasher to the differential and hubs to clean off the mud at all? I was expecting to run the washer indirectly around the areas to wash away what's there.
Also, I've never worked on the driveline, so this is a VERY basic question: how do you go about ordering a u-joint replacement? Do I just take the u-joint in to NAPA and ask for a similar replacement, or whatever their book says is a replacement? The one that I saw when the driveshaft was disconnect while towed, was very dry and barely any grease inside the u-joint, so I expect all 4 to be the same.
