I had a garage put in a new clutch a few months ago, I didn't realise they weren't very good, and since then the overdrive hasn't worked. I have checked the cable and tightened it a bit, as the knob almost came out of it's housing completely. This has made no difference except I could hear the gearing trying to engage. So pushed knob back in and came home. Looked at my manual and changed the fuse on the Trans relay, although I thought it was a strange set up with the fuse being on the outside and no wire coming from the top. But it worked perfectly for the previous 10 years as I pushed the clutch in and had a reassuring "clunk" before having that small boost of speed. Anyone any ideas? I hope it is not the solenoid, but if it is where can I get one, and more importantly does the gearbox have to come out to fit it?
Help would be appreciated.
