Page 2 of 2 FirstFirst 12
Results 41 to 55 of 55
Thread: EPAS on Buttercup
  1. #41
    7,833
    To get less turns lock to lock you would have to lengthen the pitman arm
    FWIW, that was a 1960s Stude racer trick; cut one at the bottom and one at the top and weld together. The '56 Power Hawk I drove from 1970-95 had a lengthened Pittman arm and it did steer a bit heavier, but I was young and strong. That steering box and arm is still around the shop somewhere.
  2. #42
    Sep 2015
    Sweden
    630
    If you can find it back I think a picture would be interesting.
    Josephine
    -55
    Champion V8
    4d sedan
  3. #43
    1,027
  4. #44
    1,027
    BTW - These are what I bought for doing the EPAS on my Sky Hawk... $88... https://www.ebay.com/itm/09-10-11-12...xYJJj7&vxp=mtr and this https://www.ebay.com/itm/09-10-2009-...!US!-1&vxp=mtr
    I researched different EPAS systems, and with the controller, the Toyota Corolla is, by far the least complicated to hook up...3 wires only...power, ground, and ignition on...https://www.youtube.com/watch?v=f4TYQ_KJSpc
  5. #45
    1,027
    JACK - Do you remember the length...LOA or center to center, of that lengthened Pitman Arm?
  6. #46
    7,833
    No, but I'll try to remember to measure it if I can remember to find it :>)
  7. #47
    Speedster Member colt45sa's Avatar
    Dec 2007
    fort pierce, florida, USA.
    430
    That's one reason I'm doing it. Who needs power assist over 15 miles per hour.
    Now I'm starting to sound like another guy on this forum that thinks anyone that wants more that 175 HP must be crazy. Why would anyone need a car that would run more than 60 MPH. <G>
    You're exactly right Jerry~! Driving my '55 President coupe down the road was never a problem. Parking, getting in and out of the driveway, and maneuvering in small spaces was agony. Other than lack of power steering and a/c that 67,000 mile car was my favorite of all the classics I've owned over the years. Regarding HP, the 259 V-8 with a properly tuned WCFB was more than adequate. Floor boarding it at 45mph when the secondaries opened was surprisingly strong. The mega-HP engines being produced today are downright stupid, unless you have a powerful desire to lose you license. Back in the late '50's and '60's when you didn't see a cop every 3 minutes, we might have been able to enjoy something like that on rare occasions.
  8. #48
    Dec 2007
    430
    Quote Originally Posted by karterfred88 View Post
    Yes, if we didn't have Studebakers, Haven't found an acceptable rack conversion yet, either hydraulic or electric--a center steer unit like a Chrysler or GM j car is a marginal way to do it, if you don't mind losing your Ackerman. The distance at the back of the cross member between control arm mounts is so small it doesn't leave enough room to get 6 plus inches of travel, and clear the oil pan at the same time. If someone uses an electric rack with center steer I might try it. Looked into a used Ford Taurus police rack (rear steer to get the rack motion correct) and using a traveling bar, but won't fit. Oh well, just have to live with the Bendix bag of snakes for now.
    Why not go 'balls to the wall' and install a Fat Man front clip? You can pick up five improvements at once, disk brakes, modern control arms, ball joints, rack 'n pinion steering (poweer or non-power), and correct Ackerman~!
  9. #49
    1,027
    Jerry - Where did you get the round piece, in the fire wall, that the steering shaft is going through?...
  10. #50
    Douglasville, Georgia, USA.
    3,029
    The outer shell is the original mast jacket. I machined the solid steel insert and pressed an oilite bushing into it.
  11. #51
    1,027
    Thanks, Jerry. I'm having an extra Bell Crank Steering Arm shortened an 1 1/4" and re-welded. That way, when I get home in the spring, it'll be ready to swap with my Stock one. Between the shortened Steering Arm and EPAS, the steering effort and lock-to-lock should be just about right. I'm getting just to old to handle the Stock manual steering anymore...
  12. #52
    3,029
    Tony, so far, the only thing I would have done differently is make the upper column 1/2" longer and move the EPAS unit 1/2" closer to the firewall. Where the turn signal wires and horn wire come out of the column I just barely have room for a gromet at the original Studebaker column hanger.
  13. #53
    1,027
    Jerry,Thanks...noted...
  14. #54
    1,027
    Jerry - Just about where, on your bell crank, did you take out the 1" to shorten it?
  15. #55
    3,029
    About 2" from where the drag link attaches.
    I just rechecked the lock to lock and it is 3 3/4 turns lock to lock.
