Page 2 of 2 FirstFirst 12
Results 41 to 76 of 76
Thread: 1964 Champs - T-Cabs - 8Es - forum registry
  1. #41
    Jan 2005
    , , USA.
    10
    This 1964 1/2 ton truck my Mother and Dad had on the farm. VIN E7-21452, red pickup with the long box, with the final assembly date of 8-29-63. It has a 289 engine, 4bbl carb, 4 speed and a 3.73 twin traction rear end. It also has tinted glass in all windows and H.D. springs.
    28 Cottonwood Dr.
    Sheridan, WY 82801
  2. #42
    28,501
    Nice, I do not believe I have EVER seen a T or C Cab Pickup with Full Factory Tint, rarely a Tinted Windshield even.
    Of course it was available, it's just that Dealers almost never ordered it after 1958 on Cars or Trucks, here on the West Coast anyway.
    Kentucky Bluegrass
    3,009
    8E12-6713 - 122 WB - T6 cab - for sale from salvage yard - December 2016
  4. #44
    Kentucky Bluegrass
    3,009
    8E5-138888 - 112 WB - T4 cab - parts truck in Central Texas
    This was the very last Studebaker truck my grandfather used on his farm in the early 1970s. Mostly used to take bales of hay to feed cattle. It had the wide bed replaced by a stepside, and the engine was replaced by a flathead champion and a through the floor gear shift - need to ask my father why those changes were made.
    Update: The truck came out a junk yard and was missing its engine. There was an older engine/transmission back at the farm that was in decent shape so it was installed in the truck and a hole was cut in the floor for the gear shifter to go through. Not sure why the narrow bed is on the truck, but it might have been on it when they pulled it home.
  5. #45
    Kentucky Bluegrass
    3,009
    8E7-21496 - 112 WB - T4 Cab - for sale on Hemmings web site, February 2017.
    Climitizer, overdrive, radio
  6. #46
    Feb 2017
    Arizona
    24
    Hi, I'll add my 1964 Champ to the registry.
    Owner: Robert
    I bought this truck from a nice man in Lubbock, Texas in Nov. 2016. I paid a transporter to deliver it.
    1964 Studebaker Champ---V8 engine w/factory dual exhaust---factory 4 speed floor manual shifter (?)---long box/8.5 ft.
    odometer stopped at about 63,500 mi.---engine looks untouched---all original glass---inside cab truck is very nice, original naugahyde (?) bench seat and headliner are both in very nice original condition--- radio is original---sat under a carport for about 11 yrs before I got it---tires are rotten--totally inoperable right now--all original powertrain components---driver door latch is bad, must shut real hard---has serious rust in passenger door bottom and 1/4 panel---prior owner's uncle did a DIY replacement of rusted floorboard pans---there is surface rust about the truck---underneath looks a lot better than the truck's body does---I pray no real bad issues underneath---I think the engine is a 259 cu in w/maybe a single barrel---it is a sort of tan mixed with rust color outside---the bed was painted a medium green(?)---previous owner drove it 2-3 yrs while going to Jr College in Lubbock, then I think he got a newer vehicle---he said it coughs when starter fluid is sprayed in it. Tomorrow a local mechanic is supposed to come take a look if weather calms down . My goal is to get it running, stopping, and braking like a truck should. I plan to work on rust myself, and cut worst out, and study videos about body filler. I do not want it to look pretty, it looks so awesome now, sometimes I just go and look at it. My plumber loves it, he was here to fix water heater and his Dad was a Studebaker guy, he even loved the 8.5 foot bed ( only a plumber could do that right ). The VIN number is: E721420. Last, I guess I'll need to install seat belts once I get it running.
  7. #47
    Feb 2016
    Northern Ca.
    307
    Your truck probably has a 2 barrell carb. Do post pictures when you can.
  8. #48
    28,501
    Hi Robert, Welcome to the SDC and to the SDC Forum!
    The Stromberg Model WW 6-132, 2 Barrel Carb. does not mean it is a 259, either a 259 or a 289 would have the very SAME Carb. unless ordered with a 4 Barrel.
    Check the Engine number STAMPED into the Machined flat, Pad on driver's side of the Front Corner, on Top of the Block.
    3E = a Standard 259.
    5E = H.D. 259
    6E = H.D. 289
    7E = Std. 289
    I know it's a Wacky sequence, with NO "4" and the Heavy Duty 289 ahead of the Standard one, but THAT is how they were Numbered/Identified.
    The numbers following those are just the Engine build sequence.
    Feb 2017
    Arizona
    24
    Thank you StudeRich.
    - - - Updated - - -
    Thank you, will try to get some pictures.
  10. #50
    Kentucky Bluegrass
    3,009
    8E7-21880 - 122 WB - T6 cab - for sale on Ebay, March 2017
    Climitizer, spotlight
  11. #51
    Kentucky Bluegrass
    3,009
    8E5-139408 - 112 WB - T6 cab - for sale on Ebay, April 2017
    V8 transplant, four speed, radio, and climitizer.
  12. #52
    Kentucky Bluegrass
    3,009
    8E7-21889 - 122 WB - T6 cab - for sale on Craigslist, May 2017
    Ad states it is a 289 V8, radio, climitizer
  13. #53
    Kentucky Bluegrass
    3,009
    8E7-22249 - 112 WB - T6 cab - photos from the 53rd International Meet in South Bend, Indiana, May 2017.
    Ordered from factory with 16 inch wheels, twin traction, heavy duty front and rear spring, four speed transmission, and 4.27 rear. Shipped to Wyoming. Restored by Ross Ball of Lorena, Texas back in the early 1990s. Ross updated the interior and did some engine modifications to make it more modern.
  14. #54
    Kentucky Bluegrass
    3,009
    8E7-21577 - 122 WB - T6 cab - for sale on Ebay, August 2017
    Radio, climitizer, factory rear bumper, appears to have been Parchment white originally.
  15. #55
    Kentucky Bluegrass
    3,009
    8E12-6904 - 122 WB - T6 cab - in wrecking yard in south eastern Pennsylvania
    Climitizer, direct reading gauges, four barrel carb., 5th OD transmission, factory AC, power brakes - by VIN number, this is the very last E12 produced by Studebaker.
  16. #56
    Kentucky Bluegrass
    3,009
    8E5-139162 - 112 WB - T4 cab - for sale on Craigslist, September 2017
    climitizer, converted to non-Studebaker V8 and automatic.
  17. #57
    May 2006
    Chappell hill, Tx 60 miles west of Houston
    97
    8E-7 112 wb...#21473...........engine replaced w/rebuilt 1957 289, 2 barrel carb, 3 speed o/d101_3250.jpg101_3252.jpg101_3258.jpg101_3262.jpg101_3256.jpg
  18. #58
    Kentucky Bluegrass
    3,009
    8E12-6769 - 122 WB - T6 cab - for sale on Ebay, January 2018
    4 speed, (info from the owner: CLOVER LEAF ENGINEBORED 30 OVER WITH NEW PISTONS/ NEW CAM 4 SPEED TRANS/ NEW CLUTCH AND PRESSURE PLATE, FLYWHEEL RE SURFACED,DANA 60 TWIN TRAC/ 4:10 GEARS/ 5 NEW TIRES/ BRAKES ON ALL 4 CORNERS WITH A MUSTANG BRAKE BOOSTER, NEW WIPER MOTOR/ ORIGINAL SEAT AND DOOR PANELS/ HAVE NEW KING PIN SET BUT NOT INSTALLED/ NEW HEADLINER BUT NOT INSTALLED/ HEADS MODERNIZED /R1 INTAKE WITH 600 EDELBROCK CARB WITH ELECTRIC CHOKE/ NEW TINTED DOOR GLASS AND REAR WINDOW/ FRONT AND REAR WINDOW RUBBERS/ HALOGEN HEADLIGHTS)
  19. #59
    Apr 2015
    Warren, PA
    27
    8E7-21694 Champ was bought and brought east to Pittsburgh, where it is being rebuilt and painted. 64 Champ dashboard.jpg64 Champ shift pattern.jpg64 Champ engine.jpg64 Champ tailgate repainted.jpg
  20. #60
    Kentucky Bluegrass
    3,009
    Thanks landriopa for the two trucks added to the forum - might be the most by someone other than myself in a couple years...
    And it looks like this 8E7 was already on the list....
    http://forum.studebakerdriversclub.c...68#post1000868
  21. #61
    Kentucky Bluegrass
    3,009
    8E12-6889 - 122 WB - T6 cab - write up on Turning Wheels vol . 39, no. 11, November, 2007.
    Write up from the entry:
    Manufactured on December 12, 1963. Specs are 289 V8, five speed overdrive, twin traction, T6 cab, and special paint (originally Strato blue, with Parchment white top, special paint on the instrument board. It was shipped to Klamath Falls, Oregon. Used in Klamath Falls by a welding company. Truck ended up in Tucson and was purchased by the person who restored in in 1991. Paint was changed to black.
    Photo is from inside front cover of the magazine.
  22. #62
    Kentucky Bluegrass
    3,009
    8E5-139066 - WB unknown - cab unknown - written up in the Co-Operator section of Turning Wheels, Vol 36, No. 8, August 2004.
    Author indicated that the truck was manufactuerd on September 19, 1963.
  23. #63
    Apr 2011
    Omaha NE or Soldier IA
    836
    I'm going back through this and digging the survivorness of the A.J.'s Overhead Door truck.
  24. #64
    Apr 2011
    836
    Also digging the survivorness of Studey's Speed shop. I'm really digging the orange and tusk ivory of #58 because it reminds me of Allis-Chalmers orange and creme. Grandpa Skow had the AC dealership in Moorhead, Iowa.
  25. #65
    Dec 2007
    Union, CT., USA.
    4,433
    I know a local Club Member near Me, has a 64 Champ 3/4 ton with Factory AC and of course Tinted Glass.
    Joseph R. Zeiger
  26. #66
    Kentucky Bluegrass
    3,009
    8E12-6825 - 122 WB - T6 cab - Photo on inside cover of Turning Wheels, Vol 26, No 12, January 1994.
    Write up on the photograph: "Not everyday do we receive an current photo of original owner standing with their Studebaker. Our inside front cover features just such a combination. Shown are members Howard and Cleo Taylor with their 1964 V8 3/4 ton Champ pickup (8E12-122) that they purchased new from Grisham Motors in Springfield, Missouri, on January 30, 1964. The Champ, serial number E12-6825, features a Deluxe cab and 4 speed transmission. Howard used the Champ in his welding service from 1964 to 1976. Besides being used as a work truck, it also hauled the Taylor's cab-over camper, as well as their boat. Their son, Dusty, used for a few months after Howard retired it and then it was put in storage with 240,000 miles until 1991 when restoration was begun."
  27. #67
    Kentucky Bluegrass
    3,009
    8E7-22275 - 122 WB - T6 cab - Photo and write up featured in Turning Wheels, Vol 26, No 12, December, 1994. Page 6.
    Write up: "On the left is Herman (Thoms) 1964 (serial number E7-22,275) long bed 259 V8 1/2 ton model (8E7-122). This pickup was previously owned by Frost & French, the former Southern California Studebaker parts distributor. Herman picked it up when Studebakers West purchased the Frost & French inventory in 1987."
  28. #68
    Apr 2011
    836
    I thought that Champs didn't have chrome bumpers?
  29. #69
    Kentucky Bluegrass
    3,009
    Quote Originally Posted by DougHolverson View Post
    Nope - no factory produced Champs came with chrome front (or rear) bumpers. There might have been a dealer or two who might have had them chromed to dress them up, and clearly a lot of people who have restored these trucks have had them chromed...
  30. #70
    Kentucky Bluegrass
    3,009
    8E7-21500 - 122 WB - T4 cab - photos shared on Champs facebook page.
    climitizer and some unusal custom touches...
  31. #71
    Jul 2018
    1
    This is my truck
  32. #72
    Kentucky Bluegrass
    3,009
    8E5-138884 - 112 WB - T6 cab - for sale on Craigslist, September 2018.
    Possible radio - other accessories unknown.
  33. #73
    Oct 2018
    Sierra Madre, CA
    2
    I just became to proud owner of this 1964 Champ, first thing up is to redo all the brakes, new head gaskets and change all filters and fluids. Much more to come after that as well. I already have a production order on order from the Studebaker museum, I’ll update with all the info when that comes in. This is my first Studebaker and I’m really excited! My father in law has a 61 Lark Convertible that he’s working on at the moment as well.
  34. #74
    Kentucky Bluegrass
    3,009
    Sounds great cabaum. Are you speaking about the truck in part #72 or another one unseen?
  35. #75
    Oct 2018
    Sierra Madre, CA
    2
    Oh no, I am actually referring to #45. Sorry Im still figuring out how this forum is set up!
  36. #76
    28,501
    Quote Originally Posted by cabaum View Post
    Oh no, I am actually referring to #45. Sorry I'm still figuring out how this forum is set up!
    Welcome Chris, to the SDC and to the SDC Forum!
    I have welcomed at least THREE New Members here in the last 2 days, that's a VERY GOOD Sign for the future of our beloved Marque!!
    This is a VERY easy Site to navigate, it just takes some getting used to it.
    To reference a certain Post, you go to the Post you want to comment on, then use the "Reply with Quote" button at the Lower Right. it will then be copied and you can delete the unrelated portions if you wish to shorten the Post and save Server Space, and then adding your own comment.
    You can later Revise your post with the "Edit Post" Button and then "Save", unlike some other Sites, and even Delete one, posted in error or an unnecessary one.
    A NEW String you started, cannot be Deleted by yourself, you can ask one of our Moderators to do that.
    This is a very nice looking "T" Cab 8E7-112 T4 Standard Cab Champ Pickup.
    The interior has been greatly upgraded with New redesigned Seat Covers and Door Panels.
    Carpeting and a Deluxe Horn Ring from a '61-'66 Regal Lark Type have been added and an INSIDE Hood Release from a '59/'60 Lark, a good feature!
