I am into the rear brakes on my Lark VI wagon and thought I would clean up and drain and refill the diff while the car's up (who knows if or when it's been done), but thankfully I cleaned the back cover and looked BEFORE I started unbolting things...somewhere, someone installed new brake line and they routed the line to the passenger side essentially right over the head of one of the cover bolts! NICE.
I hope this isn't too dumb a question, but can you get the line sections already formed so you can just lay them down and bolt them in? I'm not too concerned about having to flare and bend a long piece of tubing, I have a manual and could figure that out, but if I didn't have to it wouldn't hurt my feelings either.
ps, I read an earlier post about refilling the rear end and how that should be done while the vehicle's on the ground to avoid overfilling. I hope when I do that, it might reduce the leaking from the front seal. After cleaning 90% of the muck off the rear end, it looks like that's where most of my leaking from the rear is coming from. Is that a possibility or is leaking from the front seal a sign of failure always?
Leo Horishny
Sun Valley, NV
Leo Horishny
Sun Valley, NV
