Results 1 to 3 of 3
Thread: leaking spark plugs
    970
    leaking spark plugs
    I was doing some fine tuning on my flat 6 and checking the spark plugs for leaksge I poured a little water around the plugs (when engine warm) and 3 were bubbling causing a little ripple. To comfirm good contact I used a broom handle about a foot long cut it square and glued a piece of sand paper on it and ground the plug seat until it was clean and smooth on the other end of the handle I glued some fine paper to give it a polish. If you so desire you can plug the hole with a rag and later remove it with tweasers. Also while I was pouring the water on the plugs some spilled on the intake manifold and the engine fluttered and I found the intake manifold nuts were loose. A small thing but a big difference in performance Dave
    Nov 2006
    Staten Island, New York, USA.
    1,851
    Never thought of doing this. An easy diagnostic procedure. Thanks!!!
    Oct 2010
    Dundee, Oregon
    2,860
    Sometime in the past I remember a mechanic telling me that it is a good idea to periodically check bolt tightness on exhaust/intake manifold as well as the carburetor. Since then I have occasionally found these bolts have loosened and needed tightening. I'm not sure if you would ever want to use locktight on these so checking them once per year is a good practice. And yes, if these bolts are loose they can make a difference in how your engine runs.
    Your method of checking for and correcting leaky spark plugs is clever. I may try that some time. Thanks.
    Ed Sallia
    Dundee, OR
    Sol Lucet Omnibus
