Results 1 to 9 of 9
Thread: Trunk rubber
    Aug 2005
    , , USA.
    290
    Trunk rubber
    I'm about to install some new trunk channel rubber to hopefully stop a leak. Any pointers on doing so? Or is it just basically throw on some 3M adhesive and you're good to go.
    [img=left]http://www.bulletshots.net/images/stella3.jpg[/img=left]1951 Commander Starlight Coupe (aka "Stella")
    www.bulletshots.net
    www.bulletshots.net/blog
    www.alabamastudes.com
    [img=left]http://www.bulletshots.net/images/stella3.jpg[/img=left]1951 Commander Starlight Coupe (aka \"Stella\")
    www.bulletshots.net
    Central California
    18,500
    Get the old stuff all cleaned out and attend to any rusty spots with some sort of rust treatment or something to at least inhibit the rust some. Then apply thin coats of the stuff to the channel bottom and to the bottom edge of the WS and install carefully. Cut and mitre the stuff BEFORE you install it and be careful not to stretch it as you do so.
    Miscreant adrift in
    the BerStuda Triangle!!
    1957 Transtar 1/2ton
    1960 Larkvertible V8
    1958 Provincial wagon
    1953 Commander coupe
    Aug 2005
    , , USA.
    290
    I guess I should close the trunk afterwards to keep everything pressed down into place? Then check it with a hose and water after maybe 24hrs to be safe.
    www.bulletshots.net
    14,129
    As Biggs said, dry fit, cut and miter before applying any adhesive. If you follow the adhesive directions, once it's in place it's not going to move so be careful the first time.
    Brad Johnson
    33 Rockne 10
    53 Commander Starlight
    previously: 63 Cruiser, 62 Regal VI, 60 VI convertible, 50 LandCruiser
    Falls Church, VA
    7,766
    Also wipe down the rubber with lacquer thinner and let dry before doing anything else to remove any mold release or talc that may be on it. I asked about this earlier and someone recommended using a cyanoacrylate adhesive made by Loctite for the miter joints, but I was unable to locate any and just used the yellow 3M stuff.
    nate
    55 Commander Starlight
    Aug 2005
    , , USA.
    290
    Well, it's in there. I'll give it a good rinse tomorrow to see if I still have the leak. That 3M stuff sure is messy. Sorry Nate, I was already working on it when you posted about the lacquer thinner. If this doesn't work or if I have to redo any parts of it, I'll keep that in mind. Thanks for the suggestions.
    www.bulletshots.net
    The Woodlands,Texas
    1,170
    Get some 3m adhessive remover. It will take off any excess glue and will NOT hurt the paint. Also good to clean your hands. Good Luck.
    The Woodlands,Texas
    1,170
    Be real careful with the lacquer thinner. It will remove paint off.
    14,129
    That's why you use it to wipe the rubber, not the car, before installing, and let it evaporate before glueing.
    Brad Johnson
    33 Rockne 10
  1. Trunk Rubber installation
    By dong in forum Tech Talk
    Last Post: 09-01-2008, 01:03 AM
  2. rubber trunk seal
    By jmccarrol@hotmail.com in forum Tech Talk
    Last Post: 06-21-2008, 12:37 PM
  3. BEST Rubber?
    By royvaldez in forum General Studebaker-Specific Discussion
    Last Post: 12-31-2007, 11:48 AM
  4. Lark trunk rubber
    By 62champ in forum Tech Talk
    Last Post: 08-15-2006, 12:02 PM
  5. Rubber
    By desertdoc in forum Tech Talk
    Last Post: 11-30-2005, 02:02 PM
