Thread: power steering
    Feb 2012
    lincoln delaware
    52
    power steering
    I have a 59 lark wagon with a sbc I used a chevy ps reservoir pump does anyone no is this unit is to much pressure for the Studebaker and what do I have to buy to change this lark back to maneul steering the lark steering is very quick now its sort of scary
    4,511
    There is an adjustable pressure reducing device available to cure these symptoms from people like Summit, Speedway Motors, etc. I would second a guess that your pressure is too high causing the twitchyness.
    Frank van Doorn
    Omaha, Ne.
    1962 GT Hawk 289 4 speed
    Oct 2011
    Jupiter Florida
    200
    I have a Chevy (GM) ps reservoir pump (looks like a upside down V) on my truck with a 259 motor and a changed steering box type unknown. It works fine but it is sort of tall for the rest of the motor. I plain to change out to a Stude reservoir pump this week after modifying to a 2-groove pulley. Pictures here:
    http://www.flickr.com/photos/doublep...7629095604630/ Hope this helps.
    Apr 2008
    4,912
    Studebaker used the GM power steering pump on the same Bendix power steering units for the 65's & 66's so I don't think the pump being a GM pump would make any difference. It may be the pulley is too small?
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
    Feb 2012
    lincoln delaware
    52
    what do I have to chage to get rid of the ps
    7,660
    Quote Originally Posted by cutitup View Post
    Offer to trade with any one of several here who would like to add PS to their Stude. The parts interchange directly.
    FWIW, the Studes don't have enough caster for stability with PS. First, have your's aligned. Have the tech crank in all the positive caster the adjustment allows, then adjust for camber. Usually makes a noticeable improvement.
    3,550
    PM sent. jimmijim
