Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 85
Thread: The 'Doctor's Car'
  1. #41
    Banned
    Aug 2011
    Massachusetts
    12,576
    Quote Originally Posted by SN-60 View Post
    And don't let anyone tell You a '53-'55 C/K hood needs to be 'scooped' to shut over a Golden Hawk supercharger system!
    mbstude thought that the installed height of a '63-'64 R2 top mount supercharger setup is the same as the installed height of a '57-'58 Golden Hawk supercharger setup. I believe that He is incorrect, and that the earlier setup is 'taller'. Has anyone ever measured the difference in installed heights between the two?
  2. #42
    Gainesville, FL
    14,529
    When and where did I say that? I don't even remember thinking it!
  3. #43
    Banned
    Aug 2011
    Massachusetts
    12,576
    Don't know if Matt will see this, but here's a few more recent views of the supercharger install on a '53-'55 C/K. (Doctor's Car) The engine has always ran excellent with this setup!
  4. #44
    Feb 2016
    Sunnyvale, CA. 94087
    327
    I believe, Installing supercharger systems on Stude V8s under the stock C & K hoods is something that's been continuously attempted for almost as long as these vehicles have existed! Examples that are as sucsessfully well executed as yours, are extremely far and few between. It makes perfect sense that the earlier setup would be taller. That's why Studebaker used the Golden Hawk specific hood and overlay in '57 & '58 and not on the later R2 powered Hawks. However, I have never had both the opportunity and the capacity to get measurements of any useful accuracy.
    I'm sure I'm not the only one who is very curious about any specific details of your particular installation, you'd be willing to share? How much machining was done to any of the specific components that would affect the overall height? Are all the mounts and brackets as they were when it was originally produced? How does the horsepower and torque output compair to that of the same setup on the Golden Hawks? Wow, it's also got the 3 speed OD, that's just how I'd want it! I'm sorry, if I'm asking the same questions you've probably already answered thousands of times. I do remember seeing it at one of the international meets in South Bend the last time I was there.
    I personally prefer the look of the correct headlight rims.
    Thanks for posting the PIX!
    Mark
  5. #45
    South hills, Pa, .
    563
    the supercharger bracket on this car appears to be 57 58 style as it has the 4 bolt thermostat outlet
  6. #46
    Banned
    Aug 2011
    Massachusetts
    12,576
    Quote Originally Posted by S2Deluxe View Post
    Mark
    Thanks for your positive comments Mark, (and yes, the original headlight rims are back on the car!)
    As to the installation of a '57-'58 Golden Hawk supercharger system on a '53-'55 Studebaker coupe or hardtop model, it's true that there's 'no way' the hood will close over this setup without adding a 'scoop' to it.........
    I definitely didn't want to do that....so here's what I did...........two things really,...the first one is very easy,...just swap out the regular V8 front motor mounts for the 'Avanti R3' style...you'll gain 1/2" hood clearance right away.
    The second thing isn't so easy, ...I lifted the body off of the frame about 3/4", and kept it there by 'shimming', tapering the body shims down towards the rear of the car (Kind of like what Nate Altman did to get an Avanti hood to shut over the Chevy V8 engine)
    By taking these two steps I gained about 1 1/4" of hood clearance, and with the hood itself adjusted up a bit higher than normal, it shuts with room to spare!
    I'm sure the 289 CI Golden Hawk engine has more power and torque than the 259 CI engine in 'The Doctor's Car', however, I do love the way the shorter stroke Speedster engine 'winds out' while being force fed by the McCulloch supercharger....Ed
  7. #47
    Banned
    Aug 2011
    Massachusetts
    12,576
    Quote Originally Posted by acolds View Post
    Exactly, the entire system is 'stock' '57-'58, with no mods to the mounting brackets, etc.
  8. #48
    Banned
    Aug 2011
    Massachusetts
    12,576
    I definitely didn't want to do that....so here's what I did...........Two things really,...The first one is very easy,...just swap out the regular V8 front motor mounts for the 'Avanti R3' style...you'll gain 1/2" hood clearance right away.
    Forgot to mention that the stock '53-'55 C/K fan shroud needs to be trimmed back about 2 3/4" (I modified a spare shroud which I had)....Also, a '62-'64 GT Hawk style fan spacer, NOT the stock '57 Golden Hawk fan spacer, must be used!
  9. #49
    Feb 2016
    327
    I imagine you also must of used the '57 - '58 boost gauge in your dash? I'd love to see a good shot of that, if you've got one you could post?
    Mark
  10. #50
    Banned
    Aug 2011
    Massachusetts
    12,576
    Mark
    Mark, I'd love to add the '57-'58 Golden Hawk vacuum/boost gauge to the dash of this car...actually, the '55 Speedster dash ALMOST has room for it centered between the factory gauges....but the bottom line is there isn't quite enough room for it...the install just wouldn't work.
    I do have a couple of those boost gauges, and thought about mounting one under the dash 'sixties style', but that really isn't me! Take care, Ed
  11. #51
    Banned
    Aug 2011
    Massachusetts
    12,576
    What beautiful weather we had today for our annual OCEAN BAY CHAPTER 'OCTOBERFEST'.....and I was pleasantly surprised when 'The Doctor's Car' took first in the C/K division!
    .....I've learned over the years that laying down on the ground kicking my feet while holding my breath before the awards presentation REALLY PAYS OFF!!!
  12. #52
    Banned
    Aug 2011
    Massachusetts
    12,576
    Folks always get a 'big kick' out of 'The Doctor's Car'!
  13. #53
    5,541
    One thing others fail to take into account, the McCulloch supercharger is longer than the SN-60 and later Paxtons. Therefore, in mounting it sticks further forwards and hits the hood at the front edge of the case.
    The hood cutout on the Golden Hawks really just clears this point. That is why later R2 Hawks did not need any clearance blister.
  14. #54
    20,112
    Was that Division just your '55 and Dennis' '57? If so, I guess that it was a modified Division.
    I went to that meet several times. It is a nice location. The meet wasn't in the Sept. TW "What's Happening". It was in the Oct. TW that I received on Oct. 11. It might help your turn out if you had advance notice in TW.
  15. #55
    Banned
    Aug 2011
    Massachusetts
    12,576
    Here's a couple more shots of my Speedster at Sunday's show.........I installed a new exhaust system on her last week, (after 26 years!), including a pair of Thrush mufflers...I think it sounds GREAT!!
  16. #56
    Banned
    Aug 2011
    Massachusetts
    12,576
    More advance notice is always good Gary....but I thought that the turnout was pretty good anyway!.....The trophies are for 'peoples choice' and 'The Doctor's Car' was in the '53-'64 C/K class.
  17. #57
    Banned
    Aug 2011
    Massachusetts
    12,576
    On other threads we've discussed the pros & cons of using lacquer exterior paint.......Check out the 'deep' shine on the left & right fender tops of 'The Doctor's Car',....This LACQUER paint job was applied TWENTY-SIX years ago!!!!!!
  18. #58
    Banned
    Aug 2011
    Massachusetts
    12,576
    Got a new (2017) Massachusetts State Inspection sticker on 'The Doctor's Car' this morning!.....Unfortunately, now its time to put her to bed for the winter!
  19. #59
    Banned
    Aug 2011
    Massachusetts
    12,576
    The 'Doctor's Car' in its new home for the winter.....very cozy!!
  20. #60
    5,936
    I was at a friend's place earlier today, and his Avanti was beneath a nice car cover, inside a heated garage, with floating charger on the battery. Nice as that Avanti is, cannot say as I blame him. Looks like the, "Doctor's Car" gets the same royal treatment
  21. #61
    Banned
    Aug 2011
    Massachusetts
    12,576
    Thanks Joe!...Not to sure about that "floating charger on the battery" though...I'm still a bit skeptical of those things!
  22. #62
    Banned
    Aug 2011
    Massachusetts
    12,576
    That's a giant Christmas wreath someone placed on 'The Doctor's Car' when I wasn't looking!
  23. #63
    Banned
    Aug 2011
    Massachusetts
    12,576
    Getting prepared to 'roll out' "The Doctor's Car" next weekend if the weather co-operates!....I simply CAN'T WAIT!!!!!!
  24. #64
    Apr 2010
    Pattersonville, New York, .
    840
    I know what you mean. Our Chapter meeting is next Saturday, and I'm hoping the roads are clear so I can drive the Stude.
    Dwight 54 Commander hardtop
  25. #65
    Banned
    Aug 2011
    Massachusetts
    12,576
    Quote Originally Posted by 1954khardtop View Post
    And WHAT a Stude!!
  26. #66
    Aug 2005
    , , Canada.
    15,128
    From someone like you, I would have expected a much more thorough, professionally printed information sign, not something vague and loosely handwritten as I see in the photos. What does 'Reseved' mean? Who is Sheldon Henderson? and Ralph Holmes? Are they previous owners? Or do they own a restoration shop who restored it in 1965?
    Jan 2005
    Prince Albert,Saskatchewan , Canada.
    577
    Quote Originally Posted by 8E45E View Post
    Not to mention that whoever wrote the sign has no idea when to capitalize letters or use lowercase ones. Good thing it wasn't originally a teacher's car!!
    Evan Davis
    Prince Albert, Sk
  28. #68
    5,936
    Daang! Y'all are just slammin Ed
    I like to just have fun when at an SDC meet. I usually display whichever Stude I drive with a hand printed sign that says something goofy like, "Extreme Driver", then scribble a few particulars about the car below. To me, its all in fun, and never any concern about judges' points, since none of mine are show cars, other than shown on the road.
  29. #69
    17,754
    And this from an English major? (Glad I didn't read any of it)
    Quote Originally Posted by fargoguy View Post
    Banned
    Aug 2011
    Massachusetts
    12,576
    Craig,...that's 'RESCUED' (And it really is a good story!!)
  31. #71
    Banned
    Aug 2011
    Massachusetts
    12,576
    Thanks for your support Joe! ( and Joe, the Studebaker Forum, as in every other aspect of life, "Takes All Kinds" !)
  32. #72
    Banned
    Aug 2011
    Massachusetts
    12,576
    4/8/17..............Fired up "The Doctor's Car" this morning for the first time this year.....she 'purred like a kitten"!
  33. #73
    5,936
    Fired up the 62GT this morning and it ran just as it did yesterday, and the day before, and the day before...
    Gotta get round to firing up the 56J though. Its been a few months since it was driven. Can only drive one at a time, so tend to rotate them every 3-4 months. I leave the inop ones on trickle charge, and start their motors every month or so for a few minutes, year round. With electric fuel pumps on all of them, they usually fire up easily.
  34. #74
    Banned
    Aug 2011
    Massachusetts
    12,576
    [QUOTE=DEEPNHOCK;1048292]And this from an English major? (Glad I didn't read any of it)
    Troll somewhere else Jeff.........
  35. #75
    17,754
    Hilarious...
    36 replies to this thread were from yourself.
    I made one comment.
    My point was made long ago...
  36. #76
    Banned
    Aug 2011
    Massachusetts
    12,576
    Hilarious...
    I made one comment.
    PLEASE stop trying to ruin every thread I start!!!!!
  37. #77
    Banned
    Aug 2011
    Massachusetts
    12,576
    Joe, I was wondering where the electric fuel pump is located on the "J"?...Is it at the tank working in tandem with the stock Packard mechanical pump, or did you eliminate the stock pump entirely?...Thanks, Ed
  38. #78
    5,936
    Hi Ed,
    With both of the GTs now having EFI, their pumps are inside the gas tank. But on all carbed Studes I ever installed electric pumps on, including those GTs prior, and several 56Js, I have always mounted them up front. I sit them on the gravel shield, just forward of the AC condenser. There, they get cool air, and drawing fuel from the tank has never been a problem with the cube type pump, which I have always used. I also mount them on rubber stanchion type mounts, so they are quiet as a mouse.
  39. #79
    Banned
    Aug 2011
    Massachusetts
    12,576
    Joe, I'd be VERY INTERESTED to hear more about the EFI setups on your Hawks! (brands, difficulty of install, cost, etc)...Thanks..Ed
  40. #80
    5,936
    Hi Ed,
    I have written several times here about the GTs' fuel injection. It a setup by a guy named Bill Hamilton, who calls his business, "Hamilton Fuel Injection", or HFI for short. Just do a search in the archives here and you can probably read about it ad nauseam. That's because I am very much impressed with HFI, so have tried to pass it on.
