Past couple of weeks, Barney has been exhibiting a new behavior when starting.
Does this sound to you like perhaps a starter winding is opening up from heat soak and the field's not strong enough to spin the engine as a result? Time to take it off and get it rebuilt? Or is there something else I should look at? Battery is fairly new and tests fine.
Thanks!
- When he's cold, the engine spins over normally.
- When he's been driven, parked, and turned off for a short time, the engine seems to "stick" on each compression stroke when I hit the key to re-start.
Sounds like: "whir" pause "whir" pause "whirrVROOOM!"
Thanks!
