Is there a replacement duel piston M/C for a 62 Lark. David
Master cylinder
Originally posted by prez55 View PostIs there a replacement duel piston M/C for a 62 Lark. DavidFred
would the same DUAL master cylinder work on both power & manual brakes for a 62?? Is another used that you dont have to make so many changes in the lines & brake light switch?59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
I've used a MC from 60's-early 70's AMC products which have a 1" bore. You must be careful about interchanging MC's between power v. non-power brake units . I'm told & parts books indicate there is a difference. Also you would need to change the front "T" to convert to a dual system on a '62 since it would have been only a single system from the factory. Good luck! Rob in PA.
Originally posted by 53starliner View PostAsk for one for a 70 Nova with drum brakes. That's what I use on my 62 Lark. The lines enter from fender side, and need the larger fittings. Also, need to change the brake lite switch arrangement, either a switch on the pedal, or a tee on the front brake line to mont the pressure switch.
63' Stude stock and I believe AMC fro early 70's are 2-bolt. FWIW...the 63' had a reinforcement plate tacked onto the firewall. I chiseled it off, hammered it flat on the vise pad , then installed between MC and firewall on the 62' which did not have one. Might make a slight difference in rod length, probably not...
Originally posted by jackb View PostI'm presently swapping my 63' Cruiser's dual, non-power unit directly onto my 62' wagon. Rob's on with changing the brass tee when doing so...it looks like the steel lines are pretty much the same.....StudeRich
I used a 68 Mustang on my 62 Daytona ragtop, I used my disc brakes and no power booster, stopped great, ports go out towards the fender, giving more clearance for the valve cover.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
