Results 1 to 16 of 16
Thread: Studebaker script V8 valve cover?
    Dec 2009
    Port Lambton, , .
    802
    Is there such a thing, did studebaker ever make one?
    Banned
    Aug 2011
    Massachusetts
    12,576
    TO: johnod,----- Nope, .....Wish they did!
    17,813
    Studebaker never made them, but several others have over the years....
    President Member Sdude's Avatar
    Dixon, CA, USA.
    3,032
    It never fails to surprise me how many people tell me they didn't know studebaker made engine covers like these.
    Jon Stalnaker
    Karel Staple Chapter SDC
    Dec 2009
    Port Lambton, , .
    802
    Quote Originally Posted by Sdude View Post
    Thats cause we all threw them out whe we improved them, along with all those 57 chev FI units that didn't work.
    Dec 2009
    Port Lambton, , .
    802
    Those are nice, who made those?
    Dec 2009
    Port Lambton, , .
    802
    Quote Originally Posted by SN-60 View Post
    That unfortunately is what i thought, but no harm asking, thanks.
    Sep 2008
    calgary, alberta, Canada.
    2,516
    John, make your own! Lots of Studes have cast 'Studebaker' script that will fit on sbc valve covers. Funny, but earlier this week I was making plans to make my own for my car, just can't decide if I'm going to use cast stude script,or champion script or 283 studebaker valve cover stickers...regardless, I have an old set of Cal Custom finned aluminum valve covers that I'm going to mill the center two fins flat and then attach the script, or the stickers on the flat area. I'm just trying to decide what to do to for an oil filler for the engine, because the valve covers have no provision for that, so I would have to put the oil fill tube back on the intake manifold, but was kinda wanting to update to a more efficient aftermarket manifold that has no hole for an oil filler. Regards, Junior.
    1954 C5 Hamilton car.
    Dec 2009
    Port Lambton, , .
    802
    Quote Originally Posted by junior View Post
    If you can mill for script you should be able to mill for a push in breather/oil fill cap, I would think.
    6,940
    Junior
    In case you are planning to put an opening in the valve cover for a PCV valve, I know you know that a baffle is needed. In case you don't know, Summit, Jegs, etc carry gaskets that allow the push-in style addons and have a baffle built in. Makes equipping a valve cover with a baffle a non-event.
    Sep 2008
    2,516
    Quote Originally Posted by johnod View Post
    yup...could do that, but don't really want to put the oil filler/breather on the valve covers, like the clean look of just the finned covers. Went out to the garage to revisit things and work on my over drive handle/manual choke cable project. Looking at my old school intake manifold, I don't know how the oil fill tube/breather cap assembly will clear my (new)chrome thermostat housing...looks like they will hit each other. The t-stat housing has a bung that I put the thermo switch sensor for my electric fan into. Not too sure how I would switch things around. Regardless, I measured the Champion and Studebaker scripts on my grill bars (about 43.5 cm)so they will take just about the whole length of a SBC valvecover, but I think they would look great. My Cal Customs have a crown on them (looking from the side) so I would have to gently bend the script to match the contour of the crown, but this should be ok because they are made out of pot metal, and should be able to be bent this slight amount...one would hope. My brother glued some Pontiac script (Acadian Canso) onto his stock sheetmetal sbc valvecovers with silicone...they've stuck on for about 5 yrs now, but he alas, he has not run the engine yet, so it's yet to be determined if it this would be effective way of attaching the Studebaker script. Regards, Junior.
    Sep 2008
    2,516
    Junior
    hey Bob, thats great to know, because I was wondering that this afternoon. Shone a flashlight down the oil fill hole of my cheapie chome steel valvecovers and couldn't see how the baffle was attached. No evidence of spot welds on from the outsides of the covers...so I was wondering what I would do for baffles if I had to go with my breathers/caps in my valve covers. Trying to avoid that as I want to keep the clean look of the finned Cal Customs with no hiccups. A little confused how the gaskets would have a built in baffle, did you mean the the grommet thingie that the pcv valve gets pushed into has a built in baffle? Regards, Junior.
    6,940
    These are what I used on the 83 Avanti when I adapted the Brodex valve covers. So far so good after about 500 miles.
    http://www.summitracing.com/parts/MOR-68776/?rtype=10
    I just mill a 1.25" hole where it clears the lifters and pop in the baffled gasket and PCV valve. They make them in a couple of ID's
    A couple of companies make variations if you want to search for other options.
    Sep 2008
    2,516
    bob, thanks for the link. How do you get oil in the engine with these, do you have remove the whole grommet? Thanks, Junior.
    6,940
    Junior
    I just use it on the PCV valve, the oil filler is just a normal gasket and the cap has filter in it so the baffle is not needed.
    The drivers side is the filler (no baffle) and you can just make out the PCV valve (baffled) on the passenger side. These are a set of resurrected covers from an older circle track car. Recycling at it's best.
    I don't have an oil consumption problem with the configuration. It does use a fair amount of 91 octane though.!!!!
    Dec 2009
    Port Lambton, , .
    802
    Junior
    I also use those baffled grommet/inserts, you could remove it, or what I do is use a funnel long enough to go through the baffle for adding oil.
    Otherwise it's a hell of a mess.
    Care to guess how i know that?
