Results 1 to 29 of 29
Thread: 1950 studie
    Speedster Member Rooneytoons's Avatar
    Aug 2012
    United kingdom , England
    268
    1950 studie
    Hi guys can anyone tell me is there a website I can use to see what the difference is between the 1950 bullet nose studebaker commander's ???
    President Member (S)'s Avatar
    Aug 2010
    Ferndale, Washington
    1,740
    http://www.cadvision.com/blanchas/ID...erModels4.html The body tags and trim codes on the car would help ID it too.
    27,541
    Not sure what models you are trying to separate from others, but when it comes to spotting a '50 Commander, the first and most noticable thing to look for is those LARGE Headlight Rings with larger Parking Lights in them.
    All '50 Commanders and Commander Land Cruisers have those, and '50 Champions and all 1951's do not.
    Also, due to the Big Commander Six engine the entire front clip: hood, fenders etc. are longer on '50 Commanders.
    Hope this helps.
    Aug 2012
    268
    Quote Originally Posted by (S) View Post
    That's helpfull shame the pictures ain't clearer
    Aug 2012
    268
    Hope this helps.
    This helps as well , are the hood emblems the same and the chrome strip on the front fenders do they light up ???
    4,409
    Quote Originally Posted by Rooneytoons View Post
    It depends on your definition of emblem.
    The hood emblems, the painted brass coat of arms just above the bullet nose, are the same.
    The hood ornaments, made of chrome and clear plastic are different. The Champion has a clear vertical fin, while the Commander had a horizontal clear plastic spear or dildo.
    The fender ornaments, which were standard on the Commander/Land Cruiser only do NOT light up. I must have been asked that question a hundred times when I first got my 50 Commander 40 years ago.
    The instrument panels are different. The Commander/Land Cruiser has three large round clusters that, from left to right, hold the gauges, the speedometer, and the clock or clock blank off. The Champions have one half round cluster that has the speedometer in the center and top and the gauges alongside each side.
    The Commander/Land Cruiser has 5 lug wheels, while the Champion has 4 lugs per wheel.
    If you can look under the hood, there is an ID plate on the firewall, on the right side of the car, that tells everything about the car and it is in BIG letters/numbers so it is easy to see.
    17A means Commander/land Cruiser and 9G means Champion. The letter tells the body style/coachwork, and more. If you can tell us what this plate says, we will all know a lot more about the car.
    The Commander/Land cruiser cars have two criss-crossed steel rod braces between the firewall and the upper radiator mount to help support the extra weight of the extra long front fenders and hood
    13,883
    Sean,
    As I read it, your question is strictly about 1950 Commanders. Is that correct?
    The "bullet nose" Studebakers were built in 1950 and 1951, in Land Cruiser, Commander and Champion models.
    The Land Cruiser was a long wheelbase luxury four door sedan with an extra wing vent window in the back doors and a Commander drive train.
    The Commander was equipped with the more powerful engine (245 cid L-head six in 1950 and 232 V-8 in 1951).
    The Champion had a small 170 cid L-head six. Commander and Champion were both built in a variety of body styles: convertible, 2-door sedan, 4-door sedan, 3-passenger business coupe, 5-passenger Starlight Coupe; and both models also in a variety of trim levels.
    There were a variety of styling changes between 1950 and 1951 that make them easy to tell apart.
    Perhaps we can be more help if we can narrow down your question.
    Aug 2012
    268
    What it is guys is Im about to import a commander into England from America and I'm just collecting info on the different commander models , I've asked the guy to send me a photo of the I'd plate so i can confirm which model it is , I do know from what I've read here that it's a 5 passenger model ( I think ha ha ) the reason is to give the ppl who register cars here in england as much info as I can about the car as it will have a brand new title (V5 log book here)
    You guys have been a great help
    4,409
    The 5 passenger model is also called a starlight coupe. It was the styling sensation of the day, with a four piece rear window that wrapped all the way around the car. That window, along with the bullet nose, made the car one of the most distinctively styled cars available in 1950.
    If yours truly is a 50 Commander starlight coupe, you have quite an impressive machine in your automotive stable. Congratulations.
    The body tag should start with 17A-C something. 17A is 50 Commander and C is starlight coupe.
    Please let us know what the body tag says when you find out.
    13,883
    3,581
    Will a coupe fit only 5 people and will a sedan 6 and if so whyscome? Also, will 3 adults fit into the seat of a business coupe? cheers jimmijim
    27,541
    Quote Originally Posted by jimmijim8 View Post
    The Starlight Coupes have two large deep and wide rear armrests with secret storage compartments under the hinged lids, the seat is narrower than a 2 dr. Sedan that seats 6. Convertibles are also 5 Pass.
    Front seats are all the same so Business Coupes and all models hold 3.
    13,883
    Yes, Jim; depending on their likeability. No if any of them are named Chris Christie.
    Now...if they happen to be really skinny...the limit will only depend on how skinny they really are.
    Aug 2012
    268
    Here's another one guys is the width of all the commanders the same ??? Just under 67 inches ???
    4,409
    The body is the same on Champion and Commander from the firewall back. The widest part of the car is the bulge in the front of the rear fender.
    When do we get to see pictures of the car? You must have seen a picture to buy it.
    Aug 2012
    268
    Ok guys had a photo of the plate today it reads. 17A-C3 608
    I will upload some photos when I have the car signed over to me I wouldn't want someone else putting in an offer before I get chance to drive it etc etc
    May 2008
    Barrie, Ontario, Canada.
    3,497
    She's a Commander Starlight!!! The trim code (3) would be deluxe?
    Aug 2012
    268
    Quote Originally Posted by warrlaw1 View Post
    Cheers mate I did find this out earlier on today via this website http://hem.bredband.net/b284654/project/1950_2.htm
    But thanks for your input do you know what the 608 number is all about
    President Member Tom B's Avatar
    St. Louisville (NE of Cols.), OH, USA.
    3,557
    608 is the sequential number of the body from the weld shop. It's a rough indicator of when it was welded up relative to the whole year's production. Once you find out how many were produced in (in this case) 1950, you will know about when in the sequence it was welded. It does not infer when the car was built, just when the body was welded.
    Tom Bredehoft
    '55 President (6H Y6) State Sedan....back on the road, again and again and again
    '16 Subaru Impreza Hatchback, (MIJ)
    Two out of three Indiana built cars
    Aug 2012
    268
    Quote Originally Posted by Tom B View Post
    There was 4,383 produced
    Aug 2012
    268
    Sep 2012
    dallas
    8
    Good morning all! Now I can figure out what mine is thanks to this 77 Iron 50 stude 006.jpg
    Thread..I hope 9G-F1 15429 says on tag.
    4,409
    9G = 50 Champion
    F = two door sedan
    1 = "custom" trim level (a stripped down model introduced in mid-year in order to offer a lower priced car to compete with the big three price wise) It was called a custom, but that did not mean it was customized by anyone.
    15429 = 15429th two door body built in 1950
    My first Studebaker was a 9G-F1.
    Sep 2012
    dallas
    8
    Thank You Sir! This is my first also..Swapped one of my Harleys for Her..
    Dec 2009
    Port Lambton, , .
    802
    That looks pretty slick, i like it!
    Congrats.
    Aug 2012
    268
    Quote Originally Posted by johnod View Post
    Congrats.
    Thank you as of Monday morning it will be starting its journey to England
    President Member deco_droid's Avatar
    Feb 2010
    DFW, TX, USA.
    792
    Nice, with just a bit of customizing. Do you know yet if it has the original engine, or if that has been swapped, and if so, for what? Also, I just bought a car like this and am looking at different wheels at a later date. Do you know what size rims are on your car yet? Thanks...
    Aug 2012
    268
    Quote Originally Posted by deco_droid View Post
    The only thing I can tell you at the mo is its all on corvette running gear engine 350 trans 700r
    Feb 2010
    DFW, TX, USA.
    792
    Thanks. Drop back by with more photos if you get a chance.
    1950 Commander Starlight Coupe
    Regal Deluxe Trim
    Automatic transmission
    46k original miles, 4th Owner
