Thread: Resistor Pictures Please
    Jan 2011
    1,549
    Gentlemen,
    Would someone who has an R-1 engine if possible please post some pictures of the resistor that sits on the top of the coil. I believe thee is a missing piece on my bracket as the resistor doesn't sit in the middle of the coil...but juts out at an angle.
    Different angles would be great.
    Thanks in advance for the help!
    Apr 2008
    Seligman, Az USA.
    4,978
    I took a picture of it but need the wife to download it before I can post it here. It is an R-1 engine built in October 63.
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
    Jan 2011
    1,549
    Many thanks Warren!
    Quote Originally Posted by Warren Webb View Post
    Apr 2008
    Seligman, Az USA.
    4,978
    The coil is out of its position but everything else is as South Bend assembled it.
    The bracket that it is mounted on comes from the intake manifold where it is held by the 2 screws that hold the coil on non-R engines.
    64 Zip Van
    66 Cruiser V-8 auto
    Jan 2011
    1,549
    Warren could you remove the number two spark plug wire (first plug on pass side front of car) and measure it streatched out.
    Thanks for your assistance.
    Jul 2006
    Camden, SC, USA.
    165
    Resistors either work or they don't, right?
    Just what are resistors supposed to do?
    Bellingham, WA, USA.
    14,028
    Quote Originally Posted by Buck View Post
    They drop the voltage to the coil from 12v to 7-8v. Generally, 12v cars with points ignition will start on a full 12v, but as soon as the starter disengages, switch to 7-8v in order to keep the points from burning and the coil from over heating.
    Dick Steinkamp
    Bellingham, WA
