i just had the springs replaced on my 1962 lark.
i also replaced the front brake pads, master cylinder, wheel cylinders, brake pads, upper and lower control arm bushings and the rubber hoses. when you hit the brakes hard the car pulls to the left. theres plenty of pressure in the cylinder and the brakes seem to be working properly.
1. the new springs are a little shorter than the factory springs.
2. the wheelbase is over / under by about a half inch on either side. 112 1/2" on the driver. 113 1/2" on the passenger. i did not replace the trunnion bolts but they're pretty stuck. do you think that i can get enough caster adjustment from new trunnion bolts to correct the wheelbase? will that correct the pull on the brakes?
3. i did not replace the drums but as far as i know i think they're still within spec.
has anybody else encountered this issue with replacing the springs on the front end?
Thanks.
Fitz
1962 Studebaker Lark 4 door 259 v8
Thanks.
Fitz
