64' 289. I suspect that my distributor is installed 180 degrees off. Is the vacuum advance supposed pointing toward the drivers side or the passenger side? If the passenger side then mine is off. Also, can't seem to find a diagram for firing order for the distributor - where is #1 on the distributor supposed to be? Need info ASAP.
Distributor Question
I'm sure others will correct this if I'm wrong. My '53 (6 volt Delco) distributor has the vacuum advance pointing due east (with the car pointing north) The No. 1 spark plug wire is pointing north, it is the forward most wire.
[img=left]http://www.alink.com/personal/tbredehoft/Bothcars.jpg[/img=left]
Tom Bredehoft
'53 Commander Coupe
'60 Lark VI
'05 Legacy Ltd Wagon
All three Indiana built OD cars
My finger in on the number 1 cylinder wire on my 64 289 engine. The vacuum advance is pointing towards the passenger side.
Leonard Shepherd
The location of the vacuum advance tells you little about the timing, it the position if the rotor relative to number one. If it's a 180 out of time, it'll point to number one on the exhaust stroke, not compression.
JDP/Maryland
64 Daytona HT/R2 clone
63 GT R2
63 Lark 2 door
62 Lark 2 door
60 Lark HT-60Hawk
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
JDP Maryland
Leonard, your number one is in the wrong place, but it makes little difference as long as it's timed right.
JDP/Maryland
63 GT R2
63 Lark 2 door
62 Lark 2 door
60 Lark HT-60Hawk
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
JDP Maryland
quote:Leonard, your number one is in the wrong place, but it makes little difference as long as it's timed right.
JDP/Maryland
Leonard Shepherd
Two or three south of you finger. It really does not matter which is number one on the distributor. Here is what I did two weeks ago after my distributer caved. You should remove the #1 cylinder spark plug (Drivers side closest to the rad - 1,3,5,7) stick your finger over the spark plug hole and find the compression stroke. Install the distributor and where ever the rotor is pointing is your #1 wire, counter clock wise to the firing order from there. My #1 wire was two south of your finger.
1964 GT Hawk soon to be R2 Clone1964 GT Hawk
PSMCDR 2014
PSMCDR 2013
Victoria, Canada
Thanks. It is running real good, but I will change the wires when I get a chance. The guy who put the wiring harness in for me just drove it and told me it was scary!
Leonard Shepherd
quote:[ It really does not matter which is number one on the distributor.
Tim K.
'64 R2 GT HawkTim K.
\'64 R2 GT Hawk
I've advised Leonard not to change the wires, not to try to locate No. 1 TDC and put the rotor in the correct location. This will mess up the oil pump drive, the distributor won't 'seat' until the oil pump is properly lined up and things will go down-hill from there.
Tom Bredehoft
'53 Commander Coupe
'60 Lark VI
quote:Originally posted by curt
Is it counter clock wise. Does the rotor turn counter clockwise? I'm not home and can't consult my books, counter clock wise roataion seems wrong, I'm not sure on this 289 engine.
Tim K.
\'64 R2 GT Hawk
I like to "make things right," just put the dist in so that rotor points to no. 1 and body is correctly located, if it doesn't line up, just keep light pressure on the dist. body and bump the engine over with a remote starter switch, it will drop right in within half a revolution.
nate
55 Commander Starlight
quote:I've advised Leonard not to change the wires, not to try to locate No. 1 TDC and put the rotor in the correct location. This will mess up the oil pump drive, the distributor won't 'seat' until the oil pump is properly lined up and things will go down-hill from there.
Leonard Shepherd
