How is the horn button/ring removed on a 1950 Studebaker Champion. I have pulled on mine pretty hard to no avail. I'm afraid to pry on it with anything or pull on it too hard for fear of breaking it.
horn button/ ring removal
Thanks so much. I actually wanted to remove just the horn button. I'm glad I got your great advice before I did something dumb. I was able to remove the button by turning it, while applying upward pressure with my fingernails. I wanted to replace my old heavily cracked plastic Studebaker Crest button. Thanks again for your wise expertise.
Would I use this same technique with the horn button on a 1954 Studebaker 3R6-12 pickup truck? I'm having an issue with the horn making sound when I turn the steeering wheel all the way to the left. I assume that I need to adjust the sensitivity or check the wiring? Any help is appreciated.
Socko29....Welcome to the site...I'm pretty new myself, but I have found some of these guys can help out a whole bunch. Do you have the manual for your car? I am about 60% done working on my 50 Studebaker Champion Deluxe 9G. I've done all the work myself. I have the shop manual, in the garage that I use every day. Everything about our cars are weird(especially the brakes and wiring), so the manual really helps. There is a wire that sticks out of the steering box under the hood that connects to the horn. It could be grounding out--good time to replace it. I can get you the color and gage wire if you want? Rick from Des Moines, Iowa...........It's snowing here today
Originally posted by Jersey2J View PostWould I use this same technique with the horn button on a 1954 Studebaker 3R6-12 pickup truck? I'm having an issue with the horn making sound when I turn the steeering wheel all the way to the left. I assume that I need to adjust the sensitivity or check the wiring? Any help is appreciated.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Fellas. I see two green wires that lead from the column under the hood right up to the horns. They look fine under the hood, so I assume I have an issue under the horn button or in the column. The horn still unexpectedly honks when turning left. Question like socko29's: How do I remove this button without breaking it? (see image)
Thanks!
-Disconnect the battery so that the neighbors do not have to "enjoy" hearing your horn.
-Press the palm of your hand, hard, onto the horn button.
-While pressing, rotate the button and your hand counter clockwise.
it should come off
The wire usually goes bad inside the column, just as it exits the column, but it might be bad inside the column higher up. The fact that it only happens when the wheel is all the way to the left tells me that the wire is twisting into some weird position. Turning the wheel to the extreme should not affect the horn button, but the button is fairly easy to remove.Last edited by RadioRoy; 05-04-2013, 01:35 PM.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Anything over 20 or 22 gauge will work. The more flexible the wire, the better.
All the wire is doing is energizing the coil of the horn relay.
Before you pull the old wire out, solder the new wire to the end of the old wire and make a smooth connection. Then use the old wire to pull the new wire through the column.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
So if you are going to pull the horn ring to replate it, cut off the horn wire and leave in the column so that a new wire can be routed later? I have a '64.Tom - Bradenton, FL
