Originally posted by Swifster
View Post
(1) The horn button type in discussion here is the "Basic" type steering wheel which uses a Horn "Button".
(2) If you have a Model with a Horn "Ring" everything changes, the Trim "Button" is held in by an "O" Ring.
(3) If you have a newer model '61 and up, the horn wire does not go through the steering shaft, it exits under the dash with the Turn signal wires.
So in the case of a '64 I would NOT cut anything, the wire unplugs at both ends but must be carefully removed through the column and it's a very tight fit usually better done by removing the Wheel and all the wires which would be on Column Automatic Trans. Cars, the Shift Dial Light wire and all of the Turn Signal harness wires, and Stop Light wires with the horn wire to prevent damage.
Also, the late type do not get any twisting action and I have never seen one fail.
