Results 1 to 16 of 16
Thread: Salt2Salt In da hood video
    May 2010
    Minnetonka, Minnesota
    64
    We are about ready to race!
    http://www.youtube.com/watch?v=yBVnNNJgWtU
    Greg
    http://salt2salt.com racing a 53' Stude on the salt.
    http://tribaker.wordpress.com building a 37' Stude boat-tailed speedster 3-wheeler
    http://turbostude.com building a 50' bullet-nose with a turbocharged stude flathead six (site under reconstruction)
    17,992
    Sounds stout!
    Best of luck! Drive safe out and back...
    Quote Originally Posted by Turbostude53 View Post
    Silver Hawk Member JRoberts's Avatar
    Fayetteville, NC, .
    9,232
    Sounds really good. Good luck to you guys out on the Salt. You know we're rootin' for ya'.
    Gainesville, FL
    14,810
    Greg, make sure someone writes down each day's events. And take lots of photos.
    22,714
    Greg, what axle ratio does that have? I'm sure it's tall for the salt, but is certainly noticeable when getting underway. Sounds like about 2.50:1 or something! <GGG> BP
    May 2010
    64
    Quote Originally Posted by BobPalma View Post
    Actually Bob, the axle ratio is 3.89:1 which may seem unusual for a conventional Stude v8, but remember that this engine is destroked to 182" and is set up to make power between 6000 and 7700 rpm. Torque doesn't even show up till over 3000 rpm. Last year, we went 135mph on the GPS with a 4.11:1 rear end..... If you look closely, you will see the pushbar we added this year, assuming that we would need to be pushed up to 30mph due to the gearing.
    Our 190" turbocharged flathead 6 stude motor actually made more torque, at lower rpms (but less HP) and at times we ran a 2.75:1.
    Greg
    22,714
    'Good explanation, Greg; thanks. That does explain the ultra-low rpm getaway; such low torque just off idle with that short a stroke. What is the stroke, BTW? BP
    Silver Hawk Member Chris Pile's Avatar
    6,386
    Go fast, be safe, and have fun!
    Fresno, California, USA.
    3,984
    Nice to have understanding neighbors.
    KURTRUK
    May 2010
    64
    The crank was destroked to 2.5". Assuming typical allowable piston speeds and a forged crank, that translates into a very high redline, limited by valve float. We have done dyno pulls to 7600+ rpm......
    Greg
    May 2008
    Chatsworth, CA, USA.
    1,460
    Sounds absolutely ferocious!! See you on the salt this Saturday.
    22,714
    Wow! 2.5" 'Can't help but wonder about the top piston speed attained in the course of running 7600 rpm. 'Might be even less than, say, a stock 289 at 5,000 rpm. BP
    Jan 2005
    Nashville, Indiana, .
    469
    Piston speed of 54.17 FPS@7800 is the same as 5380 RPMs in a stock stroke engine.
    May 2010
    64
    Quote Originally Posted by 63larkr1 View Post
    Or, using this calculator, and assuming a "heavy duty engine" capable of 4000 feet per minute piston speeds, 9600 rpm is the redline if everything in the valve train were to hold together......I asked Centerforce to provide a clutch which they thought might handle this. We don't plan on testing the theoretical calcs......
    http://thefirstgensite.com/code/maxrpm.htm
    Greg
    President Member Nelsen Motorsports's Avatar
    Nov 2008
    Lizella/Statesboro, Georgia, USA.
    1,235
    What cam are you running?
    Lizella, GA
    May 2010
    64
    Quote Originally Posted by Nelsen Motorsports View Post
    The cam is a Comp Cam flat tappet regrind # 99-999-3 Stud 6056/6056 S112.0 Valve timing @.050 intake open @ 9 BTDC close @ 53 ABDC, exhaust open @ 53 BBDC close @ 9ATDC. Lobe separation 112.0. Gross valve .511 & .511.
    The 6056 lobe profile is one of CompCams Xtreme Energy series. At 280 advertised and 242 @ .050", it sounds really gnarly in the little 182".
    Greg
