Results 1 to 3 of 3
Thread: 4 speed speedometer drive gear
    Apr 2011
    21
    My 61 Hawk has the Borg warner T10 4 speed transmission. The speedometer doesn't work, so after checking it out, I ordered a Speedometer pinion gear (bullet) to the proper rear end size (3.07) and the proper speedometer cable from SI. After receiving the parts, I noticed the speedometer drive gear was also warn; however, I can't find it anywhere. The GM people tell me, that part is strictly Studebaker. Can anyone help?
    Jun 2005
    South Bend, IN, USA.
    508
    Since I don't have the GM number and it's corresponding BW number I can't make a direct comparison but I would find it hard to believe that the one you need is Stude only. At any rate, SI should have the drive gears in stock
    R2Andrea
    Jul 2006
    Sand Springs,, Oklahoma, USA.
    3,163
    http://ozarktrails.tripod.com/
    SDC Member 1985
Tags for this Thread
