Results 1 to 4 of 4
Thread: Master Cylinder
    Oct 2006
    Rockwood, Michigan, USA.
    246
    Master Cylinder
    I read in the repair manual that the dual reservoir MC were put on vehicles starting in 64, yet my 64 Cruiser has a single reservior MC. Which is correct and how difficult is it to change over to a dual as I like idea of having a back up in case something ruptures?
    Arnold, Md., USA.
    15,728
    If your Cruiser has disk brakes, the single is correct.
    JDP/Maryland
    63 GT R2
    63 Avanti R1
    63 Daytona convert-63
    63 Lark 2 door
    62 Lark 2 door
    60 Lark HT-60Hawk
    59 3E truck
    52 & 53 Starliner
    51 Commander
    Bellingham, WA, USA.
    14,070
    Here's a similar thread...
    http://www.studebakerdriversclub.com...TOPIC_ID=10256
    Here's the ECI dual circuit remote booster...
    http://www.ecihotrodbrakes.com/remote_booster.html
    Feb 2006
    4,154
    Yes, a Cruiser should have Avanti disc brakes and a single master. It
    would be easy to just use the Avanti II style master cylinder and do
    a split at the front Y-block. On my Avanti, I just plugged the port
    for the rear brakes in the "Y", and used a union to extend the rear
    brake line up to the dual master. You have a swinging pedal, so its
    a simple task to add an electric brake light switch under the dash. I
    recommend the bottom one on Bob Johnstones website :
    http://www.studebaker-info.org/tech/repstuavMC.html
    Mid 70's Chrysler. NAPA # 36307.
    Item#: UP 36307
    APR07
    Price: $75.99
    Bore Size:1 1/32"
    Tom
    '63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: 97 Z28 T-56 6-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires
  1. Master cylinder
    By pogo in forum Tech Talk
    Last Post: 01-26-2010, 08:37 AM
  2. T Cab master cylinder
    By JeffDeWitt in forum Tech Talk
    Last Post: 11-27-2009, 05:49 PM
  3. Help - need master cylinder for 66
    By edpjr in forum Tech Talk
    Last Post: 01-23-2009, 09:54 PM
  4. master cylinder
    By psycho_666 in forum Tech Talk
    Last Post: 07-14-2007, 08:55 PM
  5. master cylinder
    By kpcoupe in forum Tech Talk
    Last Post: 05-25-2007, 10:20 PM
