Results 1 to 14 of 14
Thread: vin #
    Jan 2007
    vilonia, arkansas, USA.
    295
    vin #
    can anything be told by a vin #??
    Kevin Phillips
    Jacksonville,AR
    53 commander
    President Member Michidan's Avatar
    Mar 2006
    Kalamazoo, MI USA.
    1,556
    Some years just the approximate build order, many others also the engine type.
    We are very fortunate in that the records from studebaker production are still available. If you contact the museum with your serial number (it's not a vin number as they are known today) you can purchase the production order and learn much more.
    President Member Jim B PEI's Avatar
    Kensington PE, Canada.
    1,510
    The production order from the Studebaker Museum will tell you most of what you need to know about how the car was built, and folks here can interpret mysterious option codes. Studebaker never had VINs, although some Avanti II have them, as they only came into effect in the last 30 years or so. It will have the engine# and you can determine from that if the engine is original to the car, or if it has been changed. Same with the interior, options and colour.
    https://studebakermuseum.org/store/production-orders/ these cost $28 for 60-66, and $43 for 36-59 (no Canadian production is available before 1960, though)
    What your serial number will tell you is what sort of engine and where it was built--57G 770202 would be a 1957 185 six built in Hamilton ON, 58H 7211889 would be a 289 V8 built in South Bend IN, and 56B 8850123 is a 259 V8 built in Vernon CA. Starting in 59, it changed to to year/engine ie 59S or SC for South Bend and Hamilton sixes, and 59V or VC for V8s, 60V/60 VC and so on.--but the newer system won't tell you what size of engine ie 259 2bbl, 289 4 bbl, 289 R1 etc.
    Jim Bartley Box 7611 RR1 Kensington PEI C0B1M0
    Atlantic Canada Club SDC
    64 Commander "Special" Daytona interior 64SC-F4 2082 #1981 170 auto-project
    63 Daytona Wagonaire 63V-P8 34470 #2711 259 O/D-daily Stude driver
    57 Champion Deluxe 57G-W4 G1390844 #4427 185 auto-driver
    Kaiser, & Boler--other stuff
    27,536
    What Jim B said. Also remember that only newer cars actually have a "VIN" number, before the required 14 ? digit VIN #'s the State Vehicle Registration Dept's. used the SERIAL number and up to 1954 Calif. and some other States used the Engine number to I.D. the vehicle. The Studebaker I.D. numbers are "Serial Numbers" used as VIN numbers.
    On your '57 Silver Hawk, you will be able to tell if it was built as a Six Cyl. or V-8, only approximately how late in the model run it was built, also if it was Assembled in the South Bend or Hamilton, ONT Canada Plant
    Jan 2007
    295
    well i have ordered the build sheet on my silverhawk!! but i am purchasing a 53 commander hardtop and all i have recieved so far is the number on the door frame. that number is V26B010 can any thing be told by this??
    Kevin Phillips
    Jacksonville,AR
    53 commander
    President Member Tom B's Avatar
    St. Louisville (NE of Cols.), OH, USA.
    3,556
    Your "Serial No." is an Engine Number. Commander serial nos. all started wtih 8
    V26B010 would be V2680I0. I was substituted for 1.
    V207001 was the first Commander motor built in '53 at South Bend. Your car would have been 61,009 after this. Hamilton, Ont. motors began with VC.
    Tom Bredehoft
    '55 President (6H Y6) State Sedan....back on the road, again and again and again
    '16 Subaru Impreza Hatchback, (MIJ)
    Two out of three Indiana built cars
    Jan 2007
    295
    how do you guys get all of this info??? you guys and girls (if girls answered) are amazing!! i plan on ordering the build sheet as soon as i can i am just to excited to wait to get the info!!!!
    ok so i understand, you say all commander serial started with 8 but then you said the first was v207001 that kinda lost me!!
    also could this actually be the original motor for a 53 if it was # 61,009??
    thanks again!!!!
    Quote Originally Posted by Tom B View Post
    Kevin Phillips
    Jacksonville,AR
    53 commander
    1,510
    If you look at my signature, my 57B Commander serial number starts with an 8. A "G" engine was a six, a "B" was a Commander V8 and it would be a 259, and a "H" would be a President V8, and that would be a 289. There was also an "L" engine which was a supercharged 289. The G, B, H, (and L) all had different serial number sequences, as did the US and Canadian cars. If you look at my two 57 G sixes, the G769739 is Canadian built, and the G1390844 is South Bend built, but both cars are nearly identical 6 cylinders otherwise.
    Yes, it all make sense of a sort after a while, once you know where to find the info. Not right away, though Every few years, just when you got used to the system, Studebaker went an changed it. It changed after 55, it changed again in 1959, it changed yet again starting January 1964, and then 65 and 66 were different too.....
    27,536
    Kevin; what these guys are saying without saying, is that the V number you gave us is a ENGINE NUMBER, you must be getting it from the Title or Registration card.
    To order the production order or get a good Serial number for a current new title, you have to actually LOOK at the forward drivers door post and copy the SERIAL number from the serial number plate!
    And YES, if that Engine (V268010) is the original and is still in the car, it IS a 1953 Commander, and the CAR'S SERIAL number will start with an 8.
    Jan 2007
    295
    ok, that makes since cause the number is off the title!! thanks
    Kevin Phillips
    Jacksonville,AR
    53 commander
    Speedster Member pyrodork's Avatar
    Sep 2010
    Minneapolis, MN
    142
    hello, i'm trying to figure out the title for my car (so i can actually get it registered in my name!). the seller said the title didn't match the car, and when i went to get it registered, they wouldn't do anything without the title (seller still has it, but gave me a bill of sale, which they didn't care about).
    thinking the seller confused the door pillar number with the number that's supposed to be on the title, i emailed the seller with the engine number to see if it matched the title. it does not.
    so, my questions... what can you tell me about these numbers, and how do i fix this fiasco (i did ask the seller to sign the title and mail it to me)?
    529278 is the number on the block... then there is a 2, D, a small circle, and i think an N underneath the number.
    G658I43 is the number on the door pillar.
    G1059216 is the number on the title.
    i'm most confused because the number on the title doesn't even remotely match any of the other numbers.
    oh, while i've got the question up here, the tag on the passenger side of the firewall is missing. is there a way i can order a new one, and how do i figure out what number was there?
    SDC Member A012633P
    SDC North Star Chapter
    MN Street Rod Assn. #21974
    1951 Studebaker Champion 2-door sedan
    1937 Plymouth Deluxe 2-door sedan
    1994 Honda Civic DX (daily driving rust bucket)
    1983 Honda Nighthawk 650
    SOLD:
    1988 Ford E-350 XL Diesel Ambulance
    Silver Hawk Member barnlark's Avatar
    Dec 2007
    Northeastern Ohio
    5,154
    kpcoupe & pyrodork, if you haven't found these lists to help SDC and Forum members identify their engines, here are the links:
    http://studebakerdriversclub.com/V8EngineID.asp
    http://studebakerdriversclub.com/tech_6data.asp
    With a search, you may, or may not some days, find several helpful threads regarding all of your questions. Title and Studebaker serial number snafus are common topics here. Titles being changed and typos being made in title bureaus, fibbing, or different rules in each state through the decades since our vehicles were first sold, will always be cause for consternation among new Stude purchasers.
    Pyrodork, I don't think anyone has come up with an exact factory stamping press for the firewall tags. Many people save and collect them, though. Maybe someone has one that will come close to what yours should be trim and engine-wise. Except for the correct number it came off the line, another tag will replace the blank spot on your cowl. It should be part of an honest disclosure procedure upon selling the car in the future, though. Good luck. You haven't even touched on the hidden serial number topic yet! Baby Stude steps.
    Sep 2010
    Minneapolis, MN
    142
    Quote Originally Posted by barnlark View Post
    hidden serial numbers? are any of those something that MAY match what's on the title?!
    SDC Member A012633P
    SOLD:
    27,536
    Possibly, if the title is for the FRAME, and the body, it's Serial number and the Title are different, due to a Body replacement, not very likely though!
