Results 1 to 9 of 9
Thread: Radiator
    Aug 2010
    Marysville, Ohio
    144
    Radiator
    I just bought a 1962 Hawk. I need a radiator. Is there a replacement to be had? I don't think the old one can be repaired. I droped it off in the Shop today and it did not look good!
    Parish, central NY
    7,277
    Proud NON-CASO
    Romans 15:13
    Deuteronomy 31:6
    Proverbs 28:1
    Illegitimi non carborundum
    13,855
    I may be in the minority here but, the only Studebaker radiators I've seen that can't be repaired are ones that have been involved in collisions.
    President Member studebaker-R2-4-me's Avatar
    Victoria, Canada.
    1,864
    Quote Originally Posted by rockne10 View Post
    I don't think your in a minority here at all. I just finished installing a re-cored radiator of my 63 Lark. The radiator shop installed a tranmission cooler pipe in the bottom section of the radiator ( for a future powershift conversion) and used a 3 row core for better cooling in the original radiator. My old radiator was not in good shape either. The new re-cored radiator sure keeps the engine a lot cooler.
    1964 GT Hawk
    PSMCDR 2014
    PSMCDR 2013
    Victoria, Canada
    Aug 2010
    Marysville, Ohio
    144
    What I was asking is there a Radiator out there that will interchange with a 62 Hawk radiator. I have found no direct replacement with other web sites.
    Victoria, Canada.
    1,864
    Quote Originally Posted by Leroy Cook View Post
    My rebuild cost me $540 with the internal cooler. Keep your Hawk stock and have it rebuilt. Good Luck
    1964 GT Hawk
    PSMCDR 2014
    PSMCDR 2013
    Victoria, Canada
    17,766
    Lightbulb
    To answer your question.
    There are no direct 'bolt in replacement' radiators sold in the aftermarket (ie: Pep Boys, AutoZone, etc)
    You will need to have your radiator repaired, recored, or replaced.
    (replaced with another used, reconditioned, or custom fabricated radiator)
    The radiator for a 1957 through 1964 Hawk should bolt right in.
    (Someone else might have more specific Hawk swap info)
    HTIH
    Frederick, Maryland, USA.
    4,044
    Several years ago when my Avanti was being rebuilt, I looked into having an aluminum radiator fabricated for the car. I did a web search and found a custom builder who said if I provided the dimensions he could build one for about $400...a bit more it required transmission cooler lines installed. It ended up I didn't need it as my radiator was in fine shape and didn't require anything but a good cleaning out.
    Unfortunately I don't have the custom radiator shop's name but I believe they were in Ohio.
    Aug 2010
    Marysville, Ohio
    144
    Many thanks for the information! I just dropped off the radiator to the repair shop and ask that it be repaired. And I left my Check Book with him! I just hope he is fair priced. As per the shop manager this radiator is better than any aftermarker radiator obtainable.
