+ Reply to Thread
Results 1 to 9 of 9
Thread: T_Cab Cyl vs 8 Cly Exhaust
    Senior Member
    Mar 2008
    OAK BANK, MANITOBA, Canada.
    121
    I have changed my OHV 6 to a 259 V8 in my 1962 T-cab. The front "Y" enhaust pipe has been joined to the existing pipes and muffler. I don't seem to have the power that I thought it should have. Would small pipes and muffler from the "6" be causing too much back pressure, thus redicing power?
    Thanks
    T-cab
    [/IMG]
    Senior Member
    Jul 2006
    Adrian, Mi, USA.
    224
    I'd put dual exhaust on it. My opinion, it's like trying to pour a large quantity of liquid quickly into and through a funnel with a real small end. Funnel overflows can't escape fast enough. With duals, you'll get the power your were expecting and nothing sounds better than a Stude V8 at the end of 2 pipes. Use at least 2 inch pipe.
    Hope this helps,
    Kim
    Senior Member
    Jan 2005
    Eureka, Ca, USA.
    755
    The exhaust will restrict some power. I'd make sure the 259 is tuned well. Check the timing, point gap, carb adjust, ect., since the engine was recently transplanted.
    Gordon
    Senior Member jclary's Avatar
    Dec 2008
    Greer, sc, USA.
    2,002
    I agree with the above comments. Another thing...what have you coupled that engine with as far a transmission and rear end?
    Senior Member
    Mar 2007
    Roseburg, Oregon, USA.
    310
    A single 2 1/2" dia. system beginning at the Y, along with an efficient low back pressure muffler would be a simpler (because of the fuel tank location), less costly, sound good and be quite adequate on a 259 powered Champ.
    Dean
    CLEM DESEE MISTY
    Senior Member
    Jan 2008
    Bay City, Mi., USA.
    1,632
    T-Cab
    The easiest thing to do is to disconnect the system after the Y-pipe and drive it. If it's better, Although loud, then it's the exhaust, if not look else where.
    I'll bet it need a tune up but the exhaust is easy to check.
    Senior Member
    Mar 2008
    121
    Concerning what it is connected to: The transmission is a 3-speed standard with OD. The rear end is 4.55:1. The carb is a standard 2-brl stromberg. The engine was rebuilt with new .20 OS pistons.
    The original 6 cyl seems to have as much pickup was the V8.
    Thanks for the replies.
    [/IMG]
  8. #8
    Senior Member
    Jan 2005
    Eureka, Ca, USA.
    755
    After reading your original post and the replies made me wonder if the heat riser was the problem?
    Gordon
  9. #9
    Senior Member
    Apr 2006
    Union Gap, Washington, USA.
    229
    With the cubic inch increase that you did you should notice quite a bit of diffference. Besides the tune up you also might check your high tension wire routing. Iyt could well be that you have some arcking goin on so plugs are fireing at the wrong time. It is real easy to spot under the hood on a dark night.
    65 2dr sedan
    64 2dr sedan (Pinkie)
    61 V8 Tcab
    61 Tcab 20R powered
    55 Commander Wagon
    54 Champion Wagon
    46 Gibson Model A
    50 JD MC
+ Reply to Thread
