Results 1 to 24 of 24
Thread: 1964 V8 PCV Valve 1561585
    ivorydan
    Guest
    I need to replace mine. Has anyone ever replaced one and knows where they are available? Thanks!
    Central California
    18,500
    Dan, if that's the one that screws into the base of the carb, I just bought a couple at NAPA. I'll see if I can find that number for you.
    Miscreant at large.
    1957 Transtar 1/2ton
    1960 Larkvertible V8
    1958 Provincial wagon
    1953 Commander coupe
    1957 President 2-dr
    1955 President State
    1951 Champion Biz cpe
    1963 Daytona project FS
    28,642
    Biggs, on the '64 Calif. smog 2brl. cars the PCV screws into the fitting welded to the lifter cover and uses a short hose to a elbow, then another short hose to the slip-on fitting in the base of the 6-132 WW Stromberg 2brl. The '63's had the adapter fitting in the old draft tube hole in the lifter cover, requiring just a PCV with 2 hose ends that also went to a slip-on fitting at the carb. the only screw-ins are 4 brl. (Stude. used a NLA Carter PCV)
    Be carefull, the threaded screw-in type of PCV that is most common in flaps now, is the GM one. It's flow is backwards, it screws into the carb. whereas the '64 2brl. Stude. screws into the lifter cover! [^]
    IF we are talking 4 brl. R1,2 it's way different, they used a simple fitting screwed into the carb. base with a ball check, and much larger flow, and then the hose to the oil pan.
    Rich.
    Studebakers Northwest
    Ferndale, WA
    Newark, DE
    1,514
    The NAPA number for the R type PVCs is: # 29267, Myer's Studebaker has NOS ones. Not sure if it is a NAPA or Echlin # however.
    Dan White
    64 R1 GT
    64 R2 GT
    Falls Church, VA
    7,766
    I'll have to call Jon on Monday; I haven't found an aftermarket PCV for the R-engines that a) works and b) has the same size hose fitting as the pan vent. I think the number you posted will work, but an extra fitting (to reduce the size of the hose) is necessary.
    yes, I'm kinda goofy about having a tidy engine compartment.
    nate
    55 Commander Starlight
    Carmel, In, USA.
    446
    Thanks. Yes its the one that screws into the AFB Carb. I'll try that no. at my local NAPA.
    5,970
    Rich.
    Ferndale, WA
    Rich-
    The above PCV design was used on my 64 289/2-bbl, originally sold (given?) to a Stude executive living in South Bend. So they apparently were used on cars beyond California. Do you know what the AC/Delco, Carter, or other number was for these oddball PCVs, apparently used on no other car? Although I suspect I already know the answer, do you know if they are available anywhere?
    Skip Lackie
    Wash, DC
    Central California
    18,500
    It was just a few months ago that I tried to get some PCV valves from NAPA. More than anything, I just wanted to see it they were still available any more. I've got an '82 edition of the Echlin ignition catalog for cars and trucks built prior to 1970. For whatever reason, it lists PCV valves amongst the ignition parts.
    They show TWO numbers for Stude V8s - 2-815 is no longer in their parts system. 2-9297 IS there and although the local place didn't have them, they had a couple in under a week for me. $6 bucks apiece.
    Curiously, they list the SAME numbers for a 61 to 63 230cu.in. 6cyl!!! There's even a valve listed for the '59 170 flathead #2-817A. I didn't ask about that one as I doubt there's many '59s out there that need one.[xx(] Further! They list a #2-817A or a #2-9270 as being vavles for 50 thru 58 Champion engines!
    Maybe this is how Stude got tagged with the notion that "they were always ahead of their time". Of course, all gearheads know that their being "ahead of their time" is the main reason they went belly up![8]
    Miscreant at large.
    1957 President 2-dr
    Feb 2005
    , , USA. Seminole , OK.
    1,466
    When sucking on the PCV valve one gets a vacuum. Which direction would that 'sucked vacuum end' go, towards the card?
    Feb 2005
    1,466
    I should pay a vacuum that stops air flow.[xx(]
    Newark, DE
    1,514
    Mr. Biggs you need to be careful at NAPA. Our local store had the right number that I gave, and they said the same thing to me it was for a 230 6cyl. It was definitely not the right valve this may be a problem between NAPA numbers and Echlin numbers? However, if you go to their website and check the number you will see the correct R Series Studebaker valve and if you are persistent you can get it.
    Dan White
    64 R1 GT
    64 R2 GT
    Feb 2005
    1,466
    I have the 2-9267 pcv valve in my V-8 President, 1963 block with the screw end of the pcv valve into the valley cover and the slip on end towards the carb. Is this reversed flow? [?][?][?]
    28,642
    CURT; I don't know which way the 2-9267 flows, (if Dan White used it in his Avanti 4brl. it's definetly backwards for the lifter cover!) so you will have to blow into the threaded end, if it flows... it's good! Also you should be able to blow the other way and get little(it may have a bleed hole) or no flow and that's fine. If not, DO NOT USE IT!![xx(]
    Unless Biggs has tried one of his 2-9297, I don't know if they will work in the lifter cover, but if they work screwed into a 4 brl. then they will NOT work in the lifter cover! Hope this helps, Rich.
    Ferndale, WA
    28,642
    Skip: Sorry; I don't have a '64 handy, but the '63 (hose to hose)original equipment Carter number is: C-3558S PCV Valve. Maybe someone can cross it over to a AC Delco #. If it can be bought, a thread to slip 3/8" hose adapter fitting can replace the old PCV and then install the new one in the hose.[^]
    Rich.
    Rich.
    Rich-
    Skip Lackie Wash, DC
    Ferndale, WA
    President Member Laemmle's Avatar
    The Empire State & The Bear State
    1,278
    I have never been able to obtain the screw in variety (back of AFB carb) from any parts house....back in the day, purchased them from SASCO, and then either from Myer, or Thibeault.
    Newark, DE
    1,514
    Here is the NAPA link for those interested:
    http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=CRB&PartNumber=29267&Description=Positive+Cra nkcase+Ventilation+(PCV)+Valve
    $4.97
    You may need to cut and past this link
    Dan White
    64 R1 GT
    64 R2 GT[u]</u>[u]</u>[u]</u>
    5,970
    Rich.
    Ferndale, WA
    Rich-
    Good thinkin' -- thanks. I have an old AC Delco PCV catalog at home. Although it doesn't list the PCV I've been looking for, I think it has an interchange listing in the back. Will check to see if I can come up with an equivalent number.
    Skip
    Feb 2005
    1,466
    I blow into the #29267 from the threaded end, no flow. Now what # do I use ? Can I turn #29267 around and use it?
    28,642
    You could do what Skip is doing, look for one that is 3/8" hose to hose, put in a threaded to slip-on adapter fitting and put the PCV in the hose, if there is no stock on correct thread to hose type with correct flow! [^]
    Rich.
    Ferndale, WA
    5,970
    Rich.
    Ferndale, WA
    Rich-
    Skip
    Rich-
    Further follow-up: all the Carter PCV numbers I have found have a maximum of three digits, with the format CV123C. Are you sure about that 3558S number?
    Skip
    28,642
    Yes Skip; I am looking at a NOS Studebaker/Carter 3/8" hose to hose type for a '63 and the stamping is very clear. It says "Carter Carburetor St Louis, MO pat pending" It also has a D3 at the bottom which I think is just a factory or date code. It has the direction of flow arrow and the Carter part #C-3558S. The problem must be that this was made in 1963, and numbers and many things have changed. Sorry that is not working.
    Rich.
    quote:[i]Rich-
    Further follow-up: all the Carter PCV numbers I have found have a maximum of three digits, with the format CV123C. Are you sure about that 3558S number?Skip
    Ferndale, WA
    5,970
    Rich.
    Ferndale, WA
    I can easily believe that. And for the record, I screwed up that format anyway -- apparently I was mixing up Carter and AC/Delco styles. The format for the Carter numbers was CV123 (no suffix letter).
    But maybe I found something even better. From a 1970 AC PCV catalog:
    61-63 Stude 6-cyl: CV633C
    61-63 Stude V8/2-bbl: CV634C
    61-63 Stude V8/4-bbl: CV633C
    64 Stude: none listed ()
    CV633C used to be called CV439
    CV634C used to be called CV440
    The date of supersession is not indicated, but apparently was in 1969. Both CV633C and 634C were used exclusively on Studebakers, so I doubt that they're still available from Delco. They could easily turn up at flea markets, though.
    Skip
    28,642
    Skip; I think that the CV633C is the threaded on one end type, but has the wrong direction of flow for a '64. Good "find" though!
    Ferndale, WA
    5,970
    More data from Stude PCV Research Dept, East Coast Div:
    From 1979 Carter catalog:
    61-63 V8/2-bbl: Carter CV125 (presumably 1555577)
    61-63 V8/4bbl: Carter CV117 (presumably 1555578)
    No listing for 6-cylinder.
    The 1979 AC/Delco catalog shows Carter CV117 crosses to AC CV735C. No AC interchange is shown for Carter CV125.
    And finally, from my "Save-this-you-might-need-it-someday" box: a used Carter number C3729S PCV for 64 V8s with the screw-in lifter cover. It appears to be dated November 1963. This is the pre-1969 Carter number; I do not know what the later number was or even if it was still in production by then. Stude part number 1561585.
    I think I'm out of things to contribute to this subject.
    Skip
  1. Brake valve/check valve/sensor part#
    By Yanqui84@gmail.com in forum Tech Talk
    Last Post: 05-03-2010, 12:57 PM
  2. 1964 Mademoiselle
    By Scott in forum General Studebaker-Specific Discussion
    Last Post: 12-01-2008, 08:59 PM
  3. 1964 R2
    By TOMMO in forum General Studebaker-Specific Discussion
    Last Post: 10-14-2008, 01:09 PM
  4. 1964 Police Car
    By satdoc2 in forum General Studebaker-Specific Discussion
    Last Post: 04-02-2008, 01:27 PM
  5. Valve body & valve seals
    By casey in forum Tech Talk
    Last Post: 06-08-2005, 02:34 PM
