Results 1 to 12 of 12
Thread: Truck bed swap?
    ddub
    Guest
    Truck bed swap?
    I have a 62 T cab with long wide box. I have a long narrow Stude bed of unknown vintage (49 or later) on a trailer. Can I fit the narrow box on the Champ? I believe this combo was not available after 61.
    I think there were some changes in the narrow bed over the years, how can I identify the bed I have?
    Don Wilson
    53 Commander Hardtop
    64 Champ 1/2 ton
    WA state
    7,880
    The 1949-55 beds were an even 4' wide.
    Central California
    18,498
    Actualy, I believe the early C-cab beds are a wee bit under 4ft. But it WILL fit just fine on your 62 truck.
    Miscreant at large.
    1957 Transtar 1/2ton
    1960 Larkvertible V8
    1958 Provincial wagon
    1953 Commander coupe
    1957 President 2-dr
    1955 President State
    1951 Champion Biz cpe
    1963 Daytona project FS
    Buda, Texas, USA.
    1,384
    My 1950 truck brochure shows the bed's inside width as 48 1/2" - here's the page:
    http://www.tocmp.com/brochures/Stude...ck_1950_14.jpg
    They became wider in 1956. I believe 51"?
    Anyway, if they put the 3" wider bed on the same frame in 1956 as had previously held the narrower bed, and if they put that 1956 vintage bed on the first T-cab trucks, then I'm betting you could put on a 1949 bed. Didn't the frame remain the same for the T-cabs as for the C-cabs that preceded them? Correct me if I'm wrong.
    [img=left]http://rocketdillo.com/studebaker/misc/images/Current_Avacar.gif[/img=left] - DilloCrafter
    1955 1/2 Ton Pickup
    The Red-Headed Amazon
    7,880
    Hi, Mr. Biggs,
    FWIW, over the past 25 years, I have hauled hundreds of 4' wide sheets of plywood, drywall and whatever and they always slide inside my 1955 box.
    However, the box is just a tad shorter than 8' long with the tailgate closed. Have to leave it down when hauling 8' goods.
    thnx, jv.
    Oct 2005
    St. Louis, Mo.
    1,556
    The beds on the TCABS had additional spacers under the rails where they went to the frame. They were welded on and looked like pieces of 3/4 pipe. You can use washers for the same effect. I found this out when I took a narrow tcab bed and put it on a transtar. I had to cut off the spacers.
    Central California
    18,498
    PackardV8, I've never actually owned a pre-57 PU, but I'll bet the extra couple of inches of width came about because with a standard of 4'X 8' sheets of building material (I wonder WHEN said standard was established), it was just easier to manuver the stuff with a couple inches to spare instead of a relativley close fit.
    How much clearance to the sides of those 4X8 sheets do you have?
    Miscreant at large.
    1957 President 2-dr
    Centralia, WA, USA
    2,123
    Thanks all for the input. This particular bed is 48.5" X 96.25" or slightly over 4' X 8'.
    Don Wilson
    64 Champ 1/2 ton
    WA state
    President Member stude53's Avatar
    Newton Grove, North Carolina, USA.
    1,357
    Hey ddub,
    Crazy question!
    Do you have a good set of fenders to put on that skinny bed?
    Regards,
    Bob (stude53)[8D]
    Buda, Texas, USA.
    1,384
    I wish my '55 truck had a 51 in. wide bed, because a sheet of 49" x 96" MDF is 1/2 inch too wide to lay down flat!
    Biggsy, that's a good question about when the standard 4x8 sheet of plywood became a standard. I only know that plywood came into popular use after WWII.
    1955 1/2 Ton Pickup
    Central California
    18,498
    I've got a neighbor that retired from selling plywood about 10 years ago. I'll ask him if he knows anything as to when the sheet size was standardized.
    Miscreant at large.
    1957 President 2-dr
    Centralia, WA, USA
    2,123
    Regards,
    Bob (stude53)
    Actually I do. I also bought the kit from Classic Enterprises to add a fender mounted spare. I was their first customer for that product. Hope to get it installed this summer.
    Don Wilson
    64 Champ 1/2 ton
    WA state
  1. eng swap
    By virg912iowa in forum Tech Talk
    Last Post: 04-15-2010, 03:43 PM
  2. C cab truck hauled from Calif to York swap meet
    By Ernie Stoltzfus in forum General Studebaker-Specific Discussion
    Last Post: 02-15-2009, 04:37 PM
  3. 52 truck rear truck bumper for sale in craigslist
    By stude52 in forum General Studebaker-Specific Discussion
    Last Post: 08-05-2008, 10:13 AM
  4. 5 Spd. DD for OD swap?
    By Mark57 in forum Tech Talk
    Last Post: 08-03-2008, 12:47 PM
  5. Swap out front bumper on 53 truck
    By 53study in forum General Studebaker-Specific Discussion
    Last Post: 07-29-2007, 06:29 PM
