Results 1 to 3 of 3
Thread: 57 Golden Hawk steering wheel assembly
    Kdancy
    Guest
    When Jerry puts the new "disc" into the hub, the turn indicator mechanism chews up the rubber insulator. He has replaced it twice. The steering column had been out of the car. Any insight or advice?
    53commander HDTP
    53 Champion HDTP
    61 Cursed Purple Hawk
    64 Champ long bed V8
    64 GT
    Falls Church, VA
    7,766
    I'm not sure exatly what you're referring to, the brass disc that the horn contact rides on? In any case, if you're getting interference between the directional switch and other pieces parts, have you checked the position of the jacket on the steering column? It needs to be set just right so that the directionals will self cancel but not so high that there's interference with the steering wheel.
    good luck,
    nate
    55 Commander Starlight
    62 Daytona hardtop
    Lake City, Fla
    1,811
    Yes, the brass disc is what is wearing fast. I'll show Jerry your post.
    53commander HDTP
    53 Champion HDTP
    64 GT
  1. steering wheel column clamp 62 hawk
    By dallastx75208 in forum Tech Talk
    Last Post: 10-17-2009, 06:07 PM
  2. Golden Hawk Wheel Color
    By Gallivan in forum Tech Talk
    Last Post: 11-05-2008, 10:08 PM
  3. Steering gear assembly lube??
    By Jeff T. in forum Tech Talk
    Last Post: 10-28-2007, 06:12 PM
  4. steering wheel exchange 61 hawk
    By studelover in forum Tech Talk
    Last Post: 08-10-2007, 03:06 PM
  5. 56-59 Hawk steering wheel and horn ring
    By Tom Hayes in forum General Studebaker-Specific Discussion
    Last Post: 07-24-2006, 01:10 PM
