Thread: Wiring 1962 Hawk Tachometer
    Alexandria, Louisiana, USA.
    484
    I just received a new Tach sending unit from Stude Int'l., No. 1555474R. Unfortunately, half of the writing on the back of the instruction was not copied and so I can't figure out what the instructions are trying to warn me about!! Does anyone have these instructions in their entirety that could scan them and send them to me. I had wanted to install the sending unit in the car tomorrow, but obviously can't without the instruction. I looked at Ray Lin's instructions, but they are apparently not for the same unit. This replacement unit apparently is not hooked up the same as the original unit.... HELP!!!
    Laisez le bon temps roulez avec un Studebaker
    President Member PeterHawk's Avatar
    Jan 2009
    Buffalo, New York, USA.
    597
    I have a sending unit from Dave T bow for my 62 GT and I think the instructions have the "cautions" you are looking for. If I can get to the garage tonight I'll contact you.
    Sarasota, FL
    312
    The used 1962 GT tachometer that I bought consisted of the tach, a rectangular unit that all the wiring came out of and sealed with some sort of plastic, a small junction, and the wiring. Photos shown.
    Sarasota, FL
    312
    Anyone happen to know if a template exists to install the factory tachometer into the dash from the front without taking the dash apart?
    Millsboro, DE
    2,212
    The hold down strap and nuts can be reached with the dash in the car, but is a PITA job. No other way to extract it, sorry.
    Independence Or 7S5
    2,120
    If you haven't already done so, remove your driver side seat. Takes about 5 minutes and saves a LOT of neck and back strain. Oh, and disconnect your battery too!
    Sarasota, FL
    312
    Ah the English language! What I was trying to poorly ask the forum is if a template exists to make the hole to install the tach on a non-tach equipped 62 GT. I was able to get a used original tach assembly but wasn't sure exactly where to make the center for the tach hole. I carefully measured the position of the clock on the left side of the dash and transferred the same measurements to the blank right side since the outside diameter for the clock and tach trim rings are the same. I made a template using the smaller rear diameter of the tach trim ring, drilled a series of 1/16" diameter holes close together, used a Dremel tool and connected the holes with an abrasive cut-off disc, and then ground the hole smooth with an abrasive cylinder. It was a lot of work! The panel is steel and not aluminum. I've got the tach installed in the dash now and I'm waiting for advice from a fellow on the GT Hawk Registry as to where to mount the electronic sending unit and junction block under the dash. I think I've got the wiring correct.
  1. 58 Hawk tachometer sending unit
    By larryyano in forum Tech Talk
    Last Post: 10-21-2009, 08:36 AM
  2. 1962 259 spark plug wiring diagram
    By studebruce in forum General Studebaker-Specific Discussion
    Last Post: 10-07-2009, 08:29 AM
  3. TACHOMETER WIRING DIAGRAM
    By 00RACER in forum General Studebaker-Specific Discussion
    Last Post: 06-01-2008, 07:17 AM
  4. 1962 lark wiring harness needed
    By jukebox in forum Tech Talk
    Last Post: 05-09-2008, 04:34 AM
  5. Hawk/Lark Tachometer to HEI? Or....
    By Steve W. in forum Tech Talk
    Last Post: 03-01-2007, 08:09 AM
