Results 1 to 12 of 12
Thread: Ross TL steering box
    Commander Member
    Oct 2007
    Rockwood, Mi, USA.
    40
    The steering box in my 55 Commander is leaking at the pitman arm shaft.The manual says use a sharp punch or awl to remove,can I assume the gearbox does not need to be disassembed to replace the seal.Is GO 90 a good lubricant fot the box or does it use a grease oil mixture,
    Silver Hawk Member N8N's Avatar
    Oct 2004
    Falls Church, VA
    7,766
    Ross box uses a special lubricant, some people use CV grease, there is a vendor that advertises in TW that sells what is supposedly a modern replacement for the original lube, there is nothing that you will find in your FLAPS that is a direct replacement for the original lube. Shop manual says you can use 140 weight gear oil to top up if it is just low.
    55 Commander Starlight
    Dec 2005
    Ferndale, WA, USA.
    28,086
    It is simi-fluid Grease for Ross gearboxes, available at S.I.
    Commander Member
    Oct 2007
    Rockwood, Mi, USA.
    40
    Thanks for the info.Remove3d the seal today Will order from SI tomorrow
    Apr 2009
    Hawthorne, California, USA.
    1,835
    I use Shell Alvania 00 semi fluid grease in the Ross gear boxes with excellent results. I've used it in several gear boxes without replacing the seals and the grease hasn't leaked out. Bud
    President Member Flashback's Avatar
    Jan 2008
    Wetumpka, Alabama, USA.
    3,817
    Bud, isn't that cotton picker grease? If so
    John Deere has a replacement. How long have
    used it?
    Tex E. Grier
    Apr 2009
    1,835
    A friend of mine in Colorado uses the Shell 00 grease in the gear cases of a couple of pieces of farm equipment so there is a 35lb pail of the grease in the shop and I took a big coffee can of it to use in Stude gear boxes. I've been using the 00 grease for years with good results and I would bet that the John Deere grease is the same stuff. Bud
  8. #8
    Commander Member
    Aug 2009
    Tacoma, WA, USA.
    58
    I just disassembled the Ross gearbox on my 1950 2R10, which would not hold 90 weight oil even for 24 hours. The cause was that the Pitman arm shaft was corroded where the seal lip contacts the shaft, which means even a new seal will not retain any kind of oil that is fluid. I have had similar leaking on early postwar (WW2) and on prewar (WW2) Rolls-Royces. Penrite "Steering Gearbox Lubricant" works fine. It has the consistency of a light Vaseline. Google "Penrite" to find the US distributor. Many years good experience on R-R cars. Cost is about the same as for the Stude Intl grease. Good luck, Phil B.
    Philip W Birkeland
    1950 Studebaker 2R10
    <jeanbirkeland@mac.com>
    253.564.9109 h
    253.279.9724 c
  9. #9
    Commander Member
    Mar 2018
    Bakersfield California
    31
    This is what makes this forum GREAT. I was looking for a replacement for the "Ross Gear and Tool" approved steering grease. A quick search and tada.
    Thank you everyone for sharing your knowledge.
    DT Holder - Bakersfield CA, USA
    1950 Commander ("Resto-Mod" in progress)
  10. #10
    Commander Member
    Apr 2017
    IA
    88
    I use John Deere Corn head grease in those old manual boxes. It must somewhat replicate what was used originally, I suspect it's the same as used in JD Cotton Pickers.
  11. #11
    Jan 2006
    Joliet , Illinois
    2,739
    A few years ago there was an article in Turning wheels on replacing the Ross steering box with a Saginaw box from 1962-66 Larks. October 1998 Turning wheels
    It reduced the steering effort and maintenance headaches.
    If you want to rebuild your Ross box.
    http://www.raylinrestoration.com/Tec...ingrebuild.htm
    https://studeblogger.blogspot.com/20...-box-info.html
  12. #12
    Mar 2013
    British Columbia & Arizona
    2,093
    Someone on this forum recommended this Lucas product for my '59 Lark, standard steering. It works great and steering effort is reduced as well and now I use it in my excavator swing assembly instead of 90W gear lube.
    It is one great product for all gears and chains.
    Lucas Chain Lubricant was developed to be a long lasting, all weather, all temperature lubricant and protectant for chains, sprockets, cables and open gears.
    Good luck,
    Bill
Similar Threads
  1. Ross SL steering leak
    By ken-renda in forum Tech Talk
    Last Post: 03-23-2010, 08:06 PM
  2. Ross TL steering Box
    By l.arend in forum General Studebaker-Specific Discussion
    Last Post: 01-06-2010, 02:38 PM
  3. Ross steering.
    By rockinhawk in forum Tech Talk
    Last Post: 08-31-2009, 09:02 AM
  4. Ross Steering Box Fluid
    By avantilover in forum Tech Talk
    Last Post: 11-25-2008, 11:34 PM
  5. Ross Steering Box Bushings
    By jngregory in forum Tech Talk
    Last Post: 04-27-2008, 11:01 AM
