Results 1 to 10 of 10
Thread: coil 62 Hawk
    Dallas, TX, USA.
    410
    coil 62 Hawk
    Is there a cross over for a coil for a 62 Hawk. Seems it got thrown away. Did n't know if I coudl get one from the local auto place. Not worried about being stock.
    Hawthorne, California, USA.
    1,819
    Most of the larger auto parts houses will have the correct coil in stock for your Hawk. If I remember correctly, the NAPA number is IC17. Bud
    Dallas, TX, USA.
    410
    Don't have a NAPA but Auto Zone should have something if it is that common. Thanks, did not know if it was special.
    Feb 2007
    Houston, Tx, USA.
    2,363
    NAPA on Harry Hines.
    Dallas, TX, USA.
    410
    Is there any way I can talk to you. I am having trouble with wires, where they go. Or if you could take a pic of your fire wall and send it to me. I can not even firure out where the coil bolts down.
    1,819
    There are a pink and a green wire connected together running along the upper edge of the firewall that connect to the positive or bat. side of the coil. The negative terminal gets the wire from the distributor. The mounting location is on the right rear side of the intake manifold behind the carburetor if the correct manifold is on the engine. Bud
    Feb 2007
    Houston, Tx, USA.
    2,363
    Jon, I will take pics this afternoon, and put them on the forum.
    Feb 2007
    Houston, Tx, USA.
    2,363
    Wiring pics. The hot-wire going to the electric choke is the overdrive solenoid hot-wire. That wire is part of the wiring harness. If you run the electric choke off of the ignition wiring, than the engine performance suffers. The choke draws a lot of juice.
    Bellingham, WA, USA.
    14,029
    A stock '62 Hawk does not have a ballast resistor like that pictured. It has a pink resistor wire instead.
    Dick Steinkamp
    Bellingham, WA
    Feb 2007
    Houston, Tx, USA.
    2,363
    I do not remember there being a resistor wire in the wiring harness from Studebaker West. It came pretty much like this.
  1. 62 Hawk Igntion Coil
    By mjeansonne in forum Tech Talk
    Last Post: 03-19-2009, 09:52 PM
  2. Coil springs 57 Hawk
    By DWard in forum Tech Talk
    Last Post: 02-02-2009, 04:45 PM
  3. 62 GT Hawk: Ignition Coil Going Out Symptoms Help
    By Pas62GTHawk in forum Tech Talk
    Last Post: 01-23-2009, 01:31 AM
  4. Coil Resistor - for '59 Hawk
    By Champion51 in forum General Studebaker-Specific Discussion
    Last Post: 06-23-2008, 11:15 PM
  5. Correct Coil Mounting Position? 63 Hawk
    By Metman in forum Tech Talk
    Last Post: 12-29-2007, 06:52 PM
