Thread: 226 vs 245
    pomona,missouri
    695
    226 vs 245
    what is the difference between the 226 and the 245 6-cylinder?????
    the champion 3-passenger coupe turned out to be a commander with a 226.would a modified 185 work ok in this body or should i go v-8
    2006,f-150,2x4,v-6,5-speed manual,8ft bed, will post stude info when i get it on the road.
    14,141
    226 has bore & stroke 3-5/16x4-1/8 and 94 Hp.
    245 has 3-5/16x4-1/4 and 100 Hp. Otherwise you can't tell the difference. 226 was used in Commanders through 1948; 245 in 1949.
    What model are you working with?
    There's too much room under the hood of any of these to substitute a 185. It would just plain look goofy. You could probably fit a V-12 in there.
    pomona,missouri
    695
    1949 3-passenger coupe with 3-speed manual.the frame is different that the 47 setting next to it. the 49 has a rear sump oil pan the 47 has a front sump oil pan. would a ford 300 6-cylinder work??? i haven't measured the compartment yet.
    10,398
    So...what would be so bad about the engine it came with? I suspect that commander business coupes are rather rare. If you are going to "Rod" it...consider a healthy Studebaker V8. If you want to go the most common and least expensive way...SBC. Either way, make sure you do it so that it proudly proclaims that it IS A STUDEBAKER!
    21,360
    I don't believe that there was any such thing as a 1949 Commander three passenger (business) coupe.
    President Member TX Rebel's Avatar
    Jul 2007
    Houston, TX, USA.
    1,926
    I have seen Pete Chrisotello's Commander Q body coupe, but don't remember if it is a 47, 48, or 49.
    Barry'd in Studes
    14,141
    Pete's '47 took a first at Lancaster. It is on page 40 of January '09 TURNING WHEELS.
