Thread: 259 & 289 engine oil capacity
    Mar 2009
    44
    When I lived in Canada and worked for my fathers Studebkaer dealer ship when we change oil and filter it took 5 imperial quarts to fill the engine. Now when I change oil and filter here in MN and put in 5 quarts the dipstick shows me almost a qt low on both my Avanti 289 and my Champ 259. Are the v8's suppose to take 6 qts with a filter change. I don't want to over fill my engine but I don't want to be starting off a qt low. The manual states 5 qts, but 5 doesn't bring it to the full mark. Can anyone out there varify what is correct and what documents there are to support this.
    Ed
    Frederick, Maryland, USA.
    4,044
    The owner's manuals were not exactly models of clarity. The manual for the '63 R1 I used to own said the engine oil capacity was 5 quarts. It didn't specify that was for the crankcase and to add a quart for the filter. Back then, many, if not most service charts said to replace the filter every other oil change. That never made sense to me...why mix five quarts of fresh oil with a quart of dirty oil. 5 quarts new oil + 1 quart dirty oil + 6 quarts of dirty oil.
    Mar 2009
    44
    I have now let my Avanti R2 sit 4 hours and checked the oil. With 5 qts it now shows half way between add and full. Earlier I checked it 5 minutes after running it and the oil level only came up to the add mark. The top end of the engine must hold a lot of oil. I guess I will add half a qt and get it to full and in the futur put in 5 1/2 qts. In the past I used to put in 6 USA qts.
    Ed
    President Member WCP's Avatar
    Feb 2008
    Glenburnie, Ontario, Canada.
    1,483
    The Cdn shop manual shows engine oil capacity as 5 us qt., 4.2 imp qt. or 4.75 litres. An additional us qt. to be added for the filter. I recall the factory authorized Studebaker mechanic that serviced my new '63 Hawk, told me during a service stop that he had adjusted the dipstick because it wasn't reading the correct level for proper operation. I think it was reading low for the correct oil fill, but I'm guessing and I can't remember if he told me the specifics of his adjustment.
    Feb 2008
    1,483
    The valley does hold considerable oil but is only a factor if you are oiling a fresh engine after a rebuild.
    Duncan, BC, Canada
    5,416
    The engine in my truck is a full flow 289 and with a NAPA gold oil filter it takes 6.5 US quarts to fill the crankcase and oil filter. I can only surmise the oil filter has some extra capacity over the original...
    <h5>Mark
    '57 Transtar Deluxe
    Vancouver Island
    The NW Overdrive Tour in Parksville, BC
    May 23 & 24, 2009; check it out at -
    http://sdcvi.shawwebspace.ca/
    </h5>
    Feb 2008
    1,483
    6 us = 5 imp. qts. Your dipstick position may be off by 0.5 us qts. The larger PH11 vs. PH25 filters that several are using should result in a higher reading, rather than lower. I'd stick with the 6 us qts. for a change with filter. As you know I'm sure, too much oil can result in air entrapment in the oil affecting lubrication efficiency.
  1. '50 Champion Towing capacity????
    By Bob in forum General Studebaker-Specific Discussion
    Last Post: 08-25-2014, 01:54 PM
  2. capacity gas tank
    By 14x7 in forum Tech Talk
    Last Post: 11-11-2009, 09:16 AM
  3. Oil Pan Capacity
    By Captain Billy in forum General Studebaker-Specific Discussion
    Last Post: 10-29-2009, 02:12 AM
  4. towing capacity
    By dallastx75208 in forum General Studebaker-Specific Discussion
    Last Post: 09-24-2008, 10:32 PM
  5. fuel tank capacity
    By mdelapp in forum General Studebaker-Specific Discussion
    Last Post: 10-02-2006, 05:26 PM
