Results 1 to 11 of 11
Thread: How to soften rubber
    President Member Lenny R2's Avatar
    Jul 2006
    Atlanta, GA, .
    892
    There was a few posts a while back on what to use to soften
    rubber anbody rember were they were at.I have a nos
    gas pedal that wont bend.
    Lenny
    Atlanta Ga.
    Lenny
    Atlanta, GA
    Speedster Member Champion51's Avatar
    Smithers, B.C., Canada
    129
    Try using a cleaning product containing lanolin cream such as the handcleaners used for heavy grease removal. I use one that I buy at Canadian Tire and use more of it on rubber parts and other stuff than I do on my hands. It is super for softening and cleaning the rubber weatherstrip. I scrub it into the rubber with an old toothbrush, and wipe off the residue with paper towels. A gas pedal might be too thick and hard for the lanolin absorption, but its worth a try.
    Dave D.
    '51 "Bulletnose" Champ
    '59 "Silver Hawk V8"
    Smithers, B.C. "Where a Stude in hand is worth two in the bush"
    Sacramento, CA, USA.
    4,744
    That thick rubber gas pedal may be a candidate for using silicone spray. I've used silicone spray on rubber weather stripping with success.
    sals54
    Jul 2007
    Burlington, NC, USA.
    45
    Lenny, Paint remover will soften rubber. Use the paint remover that adhears to surfaces so that it won't run off. You might want to do some test work if the rubber is critical for survival. Don't leave the paint remover on too long or it will really soften the rubber too much, that is why I would do some testing to get an idea of how long to leave it on a surface.
    Falls Church, VA
    7,766
    If all else fails, glycol-based (DOT3 or DOT4) brake fluid will soften rubber as well. Just don't get it near any painted surface.
    nate
    55 Commander Starlight
    Fillmore, WI
    781
    My father-in-law was chemist among other things. He said glycerine softened rubber. I don't know if you can get that any more. I had some but don't know where it is.
    Claude Chmielewski
    Studeski
    http://www.studeski.com
    Fillmore, Wisconsin
    47 M-16 Truck
    62 GT Hawk
    63 Lark
    64 Commander Wagonaire
    50 Champion Regal (parts car)
    63 GT Hawk R2
    [img=left]http://www.studeski.com/62hawk/62hawka/dakota01_250.jpg[/img=left]
    Feb 2007
    Las Vegas, NV, USA.
    891
    Stupid question (not my first!) and hopefully not too far off-topic... Why do you need to soften/bend the rubber gas pedal? Be kind with your answer to those of us who have not encountered your problem!
    Las Vegas, NV - Stop by, coffee's on!
    '51 Champion Business Coupe G899965 10G-Q4-1434
    Wetumpka, Alabama, USA.
    3,795
    Caster oil- the medicine, has worked several
    times for me. But all rubber does not react
    the same. Different types???
    Tex E. Grier
    Jun 2007
    lillian, al, USA.
    321
    To soften the brake pedel to instal on my 66 I put it in hot water to make it soft to slide over pedal, worked great. Doug M
    Jul 2007
    55
    After you mount it spray it down with STP Son of a Gun and let it soak in overnight. Wipe off any excess the next day. Keeps it soft for a long time and won't pull the oils from the rubber like some of the other rubber treatments. Spray silicon woks fairly good too.
    Jul 2006
    Atlanta, GA, .
    892
    The gas pedal is solid rubber no hinge,it bolts to the floor &
    is suposed to bend when you step on it.
    Lenny
    Atlanta Ga.
  1. how to soften tailgate chain rubber?
    By mbstude in forum General Studebaker-Specific Discussion
    Last Post: 03-18-2010, 06:56 PM
  2. windshield rubber
    By KGlowacky in forum Tech Talk
    Last Post: 05-21-2008, 10:18 PM
  3. BEST Rubber?
    By royvaldez in forum General Studebaker-Specific Discussion
    Last Post: 12-31-2007, 11:48 AM
  4. 2R-10 Rubber
    By doogietee in forum Tech Talk
    Last Post: 03-29-2006, 10:37 PM
  5. Rubber
    By desertdoc in forum Tech Talk
    Last Post: 11-30-2005, 02:02 PM
