Results 1 to 9 of 9
Thread: wiring 1157 bulbs
    President Member Michidan's Avatar
    Mar 2006
    Kalamazoo, MI USA.
    1,556
    wiring 1157 bulbs
    I am doing a full 12V rewire and can use the tail-light sockets from my 52, but I have no old wiring to reference. Maybe somebody can tell me which side of an 1157 bulb is the higher, brighter turn signal filament?
    To ask another way, if you had the bulb in your hand looking at the bottom of it, and the lower post (nearer to you) was on top, there would be a contact on the left and the right. Which is tail light and which is turn signal?
    Question 2 - I have an original backup light housing but no socket. I have a 2 wire 1157 type socket that snaps in perfectly. I can wire the feed for the reverse light into one side and just cut the other wire off. But I was thinking I might just solder the feed wire to BOTH from the socket. Will the one wire light up both filamets OK you think?
    www.studebakerhardtop.com
    6,906
    Dan The easiest way to tell is to ground the bulb and put 12v to the contacts. The brightest is the turn/brake. That's how I do it, no confusion that way.
    I'd be leary about wiring both contacts together if the lens is plastic. Could make a melted mess. If glass, probably no problem because the light won't be on long.
    Duncan, BC, Canada
    5,423
    Dan - For Q 2, I'd be headed down to my FLAPS and picking up a socket designed for a single filament bulb... they're dirt cheap.
    <h5>Mark
    '57 Transtar Deluxe
    Vancouver Island
    Are you planning to attend the NW Overdrive Tour in Parksville, BC
    May 23 & 24, 2009?
    </h5>
    Mar 2006
    Kalamazoo, MI USA.
    1,556
    thanks guys. 52 lens are glass FYI.
    Jul 2007
    55
    For a heavier version of the 1157 bulb go to the 2057
    Mar 2006
    Kalamazoo, MI USA.
    1,556
    This topic came up again for me, (I'm finally wiring the front). I found this picture that helps.
    Rather than just trust it, I did hold the socket up against a battery as Bob suggested. The picture is correct. Its the bump on the left (when the lower peg faces you) that is the brighter filament for turn signals and brake.
    Falls Church, VA
    7,766
    I take it that you are converting to 12V? Otherwise you'd want to use 1154 for dual filament and 1133 for single filament (and 1158 for dual filament if you happen to have original dual filament sockets for non-indexed pins, but you said you were replacing the sockets.)
    nate
    55 Commander Starlight
    Mar 2008
    Barrie, Ontario, Canada.
    166
    If you have the rear glass off, try foil with a sticky backing
    on the surface surrounding the bulb. I did this for my 52 and
    you will see a brighter reflection in the tailights. It may not
    be LED lighting, but it is brighter than stock.
    Aug 2009
    Virginia Beach, VA, USA.
    292
    When I tested mine using a 12V flat (transistor radio) battery, when I wired both terminals together, it made nearly no difference in brightness. So I wired in just the brighter (longer element inside the bulb) as the only active one for the turn signals I added to my 51 Champion. In that application, I added a new socket that operates only as turn signals, leaving the running/stop light sockets as they were.
    Regards,
    Clarence in Virginia Beach
  1. OT- Update on those CFL bulbs
    By bondobilly in forum "Stove Huggers" the non-Studebaker Forum
    Last Post: 03-25-2008, 08:37 PM
  2. 6v instr bulbs
    By rusty nut garage in forum Tech Talk
    Last Post: 03-16-2007, 07:44 PM
  3. Fog Light Bulbs
    By mdelapp in forum Tech Talk
    Last Post: 01-09-2007, 09:11 AM
  4. halogen bulbs 1157 ?
    By imitiday in forum Tech Talk
    Last Post: 09-29-2006, 04:19 AM
  5. 6v LED bulbs
    By tomnoller in forum General Studebaker-Specific Discussion
    Last Post: 03-17-2006, 10:40 PM
