Over the many years of Studebaker ownership (V-8's) I have found that when they get hot after a good run (summer months) they are a b-eech to re-start...especially Avanti models....all parts are normally 100% and function fine.. I have heard other Avanti owners complain about the same malady.[?]
"Age Old Problem"
In the case of Avantis, I have to wonder if when starters got replaced along the way, a standard V8 starter wasn't subbed for the higher torque Avanti starter.
Of course, as Avantis go, I can't speak from experience. I've never owned one and never endeavored to.
Miscreant at large.
1957 Transtar 1/2ton
1960 Larkvertible V8
1958 Provincial wagon
1953 Commander coupe
1957 President 2-dr
1955 President State
1951 Champion Biz cpe
1963 Daytona project FSNo deceptive flags to prove I'm patriotic - no biblical BS to impress - just ME and Studebakers - as it should be.
Miscreant at large.
1957 President 2-dr
Could also very well be fuel boiling out of the carb; much more common today than it used to be.
nate
55 Commander Starlight
nate
Starter is 100%...no heat soak....but I would tend to agree with Nate..this has been a problem for years...with all brands of fuel.... as soon as the seasons change and the temps moderate to fall then early winter.........no problem..
Hey Laemmie, Are you talking R1s or R2s or both? And do you give them a "little" gas as you are cranking them up? Works EVERY time with my R2. Never had a problem with mine on a hot start. But then mine being an R2 it does NOT have air and so it does not get above 180 degrees on the gauge--ever, not in my ownership that is (160 degree thermostat).
wagone and the R2 Avanti
Wa-Gone.........It's an R-1 with A/C....I have a 160 'stat and I do goose the gas a bit when cranking....and I am very aware(sp) of the ammeter when it finally starts....needle going 3/4 to full charge....then tapers down...that cranking sure sucks the life from the 'ol Interstate Mega.....yea, Mega my butt.............!
Laemmie, What part of the country are you in and how hot does it need to be before you experience a hard start? I still have a FEW problems with my R2, but as I said that's not one of them. But with the higher compression R1 and a/c I can sure believe it. I miss the a/c, but I sure like the poke of the R2. YEARS ago I had a '61 Hawk with the four speed and WCFB Carter. The R series engines and the R2 in particular are way beyond the '61, as it didn't have much--but I digress. Cooler weather is on the way........fall is not far off and I hope it is a LONG season here in the midwest.
A lot of us have come into this problem in recent years and it has a lot to do with the newer formulation of gasoline. It seems to have a lighter density and will evaporate easily in a carburated car, since there's a vent on top of the carb. I've thought about plugging this hole, but haven't yet. Fuel injected cars don't have a problem because the systems are sealed and there's no where for the vapors to go..
Recently, I added an electric fuel pump onto my 55 Pres because it was doing the exact same thing as yours. With a 6 volt car, it can get painfull listening to that laboring Delco, grinding away.
I installed a pull switch for the pump and use it to 'fill' the carb for a half minute or so. This also allows the Pertronix to soak up and when you crank it, it starts almost immediately.
64 GT Hawk (K7)
1970 Avanti (R3)
64 GT Hawk (K7)
1970 Avanti (R3)
