Results 1 to 31 of 31
Thread: New fuel pump, now new problem. 51 Commander
    President Member lelshaddai's Avatar
    Aug 2015
    Mesa, Arizona
    588
    My 51 Commander V8 fuel pump was having problems leaking and needed to be be rebuilt. I purchased a rebuilt original pump. Swapped them out and now I have new problems. It stutters and backfires now upon acceleration. If it is in low you can floor it no problem with no hesitation. In drive it kicks and screams, it even popped and died. The pump is working and giving accurate pressure. I even have an electric backup to push the gas through if needed. It stutters even with that pump on. The carb is rebuilt. I thought maybe something passed through and lodge in the carb. I took the top off, cleaned it up, blew carb cleaner through the needle and jets and reinstalled. If anything it made it worse. Do I need to readjust the mixture and retiming? I would not think so. It was running pretty good before. Also parked in the garage it has a large gas smell. Do not see any leak. When I removed the carb top there was plenty of gas in the areas of the floats. When I disconnected the fuel line from the pump that leads to the carb the fuel sprayed out under pressure. Stumped here.
    Jim
    62 Volvo PV544 Sport
    Mar 2005
    Los Angeles
    3,687
    Did you put a fuel pressure gauge on it to check the pressure. Sounds like it is getting flooded.
    Aug 2015
    Mesa, Arizona
    588
    Yes, I agree. I may change out the fuel pumps to see if it goes back.
    President Member Dwain G.'s Avatar
    Mar 2005
    Puget Sound, , USA.
    4,254
    Check the oil level to make sure it is not overfull and smells of gasoline.
    President Member Silverplate's Avatar
    Oct 2008
    Fort Worth, TX
    771
    Had a similar issue with a Packard, to much fuel pressure after installing a rebuilt fuel pump. Installed an inline fuel pressure regulator and at a three pound setting runs awesome.
    Fort Worth, TX
    1964 Avanti R2 #R-4986
    Dec 2005
    Ferndale, WA, USA.
    28,920
    You could need to Richen the Choke setting, is the butterfly almost Closed when Cold?
    Aug 2015
    Mesa, Arizona
    588
    Yes, butterfly is closed when it is cold. Could coil or coil wire be weak and it just came to light with the change of more fuel pressure.
  8. #8
    Golden Hawk Member
    Oct 2004
    21,567
    Quote Originally Posted by lelshaddai View Post
    Very, very unlikely or related.
    EDIT: 1) How old is the fuel that you are trying to operate with?
    2) Have you checked for fuel in the oil, as suggested by Dwain. This could cause fuel smells.
    3) Perhaps you have a small air leak in a fuel line that may have been caused in the process of changing the fuel pump. This could cause operational problems and fuel smells.
  9. #9
    Golden Hawk Member 8E45E's Avatar
    Aug 2005
    , , Canada.
    15,883
    Do you have a VENTED fuel cap?
    Aug 2015
    Mesa, Arizona
    588
    1. No I do not have a vented cap.
    2. Fuel is 12 hours old
    3. When at idle no bubbles are in the clear bowl.
    4. Checked oil earlier and it was a little low. Did not smell like gas.
  11. #11
    Speedster Member
    Oct 2016
    Fanning Spgs, Florida
    131
    ALL Studebakers use vented gas caps!!!!!!
  12. #12
    Aug 2005
    , , Canada.
    15,883
    That perhaps that may be your reason. There is no external fuel tank vent on a '51, and the cap should be vented, or you will experience fuel starvation.
    Aug 2005
    , , Canada.
    15,883
    Quote Originally Posted by rbisacca View Post
    That is incorrect. 1962 & newer Lark/Lark types had an independent vent off the fuel filler neck and directed through the trunk floor.
    Speedster Member
    Oct 2016
    131
    Quote Originally Posted by 8E45E View Post
    You're correct. It's been a long time since I sold my '63. Guess I forgot.
  15. #15
    Aug 2015
    Mesa, Arizona
    588
    I may be wrong on the cap. However the car ran fine before/
  16. #16
    Dec 2005
    Ferndale, WA, USA.
    28,920
    It could be unvented. but the Gasket looks missing so it should not be sealed anymore, you do need a New Cap but maybe not the problem.
  17. #17
    Aug 2015
    Mesa, Arizona
    588
    I don’t think the caps the problem or would’ve happened with the other pump.
  18. #18
    President Member Kurt's Avatar
    Jun 2005
    YatesCity, IL, USA.
    1,261
    Garbage in the needle and seat. I bet a little crud was introduced when the fuel pump was swapped. The popping and dying sounds like a lean condition to me. Or if crud is holding needle open a little you are flooding the engine out.
    1962 Champ
    51 Commander 4 door
  19. #19
    Speedster Member
    Nov 2012
    Millington Tn
    272
    If the gas cap is the problem it should run fine without the cap. Easy check.
  20. #20
    Aug 2015
    Mesa, Arizona
    588
    Already took the top of the carb off and clean it. Blew out the needle area. I thought that something got into the needle area also. There is gas in the bowls.
  21. #21
    Golden Hawk Member
    Oct 2004
    21,567
    To me, it looks like the gasket is there, but not in great shape. There also appears to be a small rust hole in the cap with fuel stains around it. Perhaps, depending on cap placement, sometimes it gets some venting and sometimes it doesn't have any venting.
    Try running the car without the cap and/or get a correct/proper cap.
    EDIT: Rich, you may be correct. Looking at the picture again, it is hard to tell if there is a gasket there or not. What I wrote above still applies.
  22. #22
    President Member (S)'s Avatar
    Aug 2010
    Ferndale, Washington
    2,085
    Was the pump an old one or fresh rebuild?. Is the filter good? remove it and test drive it. It comes out easy enough to check it......
  23. #23
    Jan 2012
    Seattle WA, USA.
    1,046
    Bingo! Kurt has my vote, dirt under the needle valve. I bet it belches black smoke out the exhaust too.
  24. #24
    Aug 2015
    Mesa, Arizona
    588
    I tested the new pump it is at 5 pounds, The electric backup is at 4 1/2 pounds. The new fuel filter is clean and not stopping the flow. I cleaned out the needle area but could do it again. The fuel pump is NOS with new insides. Rubber inside is flexible and new. I guess I pull the carb top off again. No votes for possible weak spark or coil?
  25. #25
    Aug 2015
    Mesa, Arizona
    588
    Change coil wire and that did not make a difference. Looked in carb and Excelerator pump is working great. Plenty of fuel is being put in the barrels. Still need to check the coil for weak spark. Just cannot figure this out. This fuel pump is better than what I had but has caused more problems.
  26. #26
    Silver Hawk Member studeclunker's Avatar
    Apr 2005
    Fawn Lodge, California, USA.
    6,898
    My '56 had a tiny vent above the fuel bowl and gas would squirt out of it. This was because a tiny piece of rubber had found it's way onto the needle seat. Since they were both black, it was to all practical purposes invisible. Thoroughly squirted the seat and needle with carb cleaner and the problem was solved. Took several tries to get the little bugger dislodged though. Now everything works perfectly.
    It could be that you have a similar issue and in this case, your engine is being drowned.
    But then, mechanically speaking, I'm a mechanical ignoramus and any advice given by me should be taken with a grain of salt.
    Home of the famous Mr. Ed!
    Ron Smith
  27. #27
    Aug 2015
    Mesa, Arizona
    588
    OK, I think problem is solved. After checking and implementing all the fuel suggestions I went to the ignition system. About 6 months ago I found the breaker plate to be sticking. Got it freed up and lubricated. It appears it got stuck again and would not move. Tested it with the vacuum pump and was able to get it to move. Relubed it and the car runs without hiccups. Also sanded the points a bit for better contact. It ran well around the block. I will give it a better tests Monday. Thanks for the help again.
  28. #28
    Jun 2005
    YatesCity, IL, USA.
    1,261
    Glad you got it figured out.
    Happy motoring!!
    1962 Champ
    51 Commander 4 door
  29. #29
    Aug 2015
    Mesa, Arizona
    588
    So I drove her to a show this morning and she still hicup under a load. However at 75 miles an hour on the freeway not a blip at all.
  30. #30
    Apr 2015
    Tucson AZ
    1,539
    Having driven the freeways in Phoenix and Mesa, 75MPH you were lucky you weren't run over.
    Bob Miles
    Pacific Southwest Zone Coordinator
  31. #31
    Mar 2011
    Damascus, OR
    1,714
    Reminds me of the old mechanic telling me - you think you have a fuel problem...90% of the time it is ignition related.
