Originally posted by 55s
View Post
1962 Hawk Restoration
Sweetolbob and Hallabutt: Bob to answer your question, the body shakes/rattles not just the suspension. I'm going to lower the tire pressure down to 30-32 psi and see if there is improvement. Hallabutt, I'm riding on Firestone FR 380 P205-75-R15 975 that came with the car and are new.
Originally posted by chet445 View PostSweetolbob and Hallabutt: Bob to answer your question, the body shakes/rattles not just the suspension. I'm going to lower the tire pressure down to 30-32 psi and see if there is improvement. Hallabutt, I'm riding on Firestone FR 380 P205-75-R15 975 that came with the car and are new.Gary L.
Not on Radial tires. Never under inflate them. What do you think all the Firestone/Ford lawsuits were over?? If it rides too hard, then change shocks. I never run any radial under 35 lbs inflation. They will last longer, run cooler and most of all be far safer.
What wheels are you running? Most aftermarket wheels are heavier than stock. The heavier the unsprung weight the harsher the ride.Bez Auto Alchemy
573-318-8948
http://bezautoalchemy.com
Originally posted by bezhawk View PostNot on Radial tires. Never under inflate them. What do you think all the Firestone/Ford lawsuits were over?? If it rides too hard, then change shocks. I never run any radial under 35 lbs inflation. They will last longer, run cooler and most of all be far safer.
Many people inflate their tires to what is on the sidewall. That is the maximum for that size tire, not necessarily what is correct for a particular car.
EDIT: I got the impression that he was running with more than 35 psi.Last edited by studegary; 02-12-2019, 06:43 PM.Gary L.
Start with the basics, double check timing at idle and at 2000 rpm to check advance. I agree with having the distributor redone if its the original.
Does sound like it's running rich, check the choke setting on carb and carb adjustment. Is this carb the right one? If it was set up for a blower it will run rich.
Tires, look and see what the build date is on the side walls. "New" means different things, date will tell for sure how old they are. Radials age differently then bias belted tires.
Agree with advice about wheels, are they straight?
These are the areas I would start looking at.64 Champ long bed V8
53 Hudson Super Wasp Coupe
I deflated the tires to 28 psi and the car ran a lot smoother not perfect but smoother. I will inflate back up to 35 psi; I need a softer tire I believe. As I stated before the tires are Firestone FR380 P205-75-R15 and were new on the car when I bought it. I have checked a number of places for a softer tire and of course they all want to sell you a set. Hard to make a decision on what would work best.
You could look on the Back of the Tires for the "DOT" followed by the Date Code, they could be hard just due to age, they say 4 to 5 years old is time to replace these short lived Radials.
Sometimes they are not "New" when purchased.StudeRich
Originally posted by chet445 View PostI deflated the tires to 28 psi and the car ran a lot smoother not perfect but smoother. I will inflate back up to 35 psi; I need a softer tire I believe. As I stated before the tires are Firestone FR380 P205-75-R15 and were new on the car when I bought it. I have checked a number of places for a softer tire and of course they all want to sell you a set. Hard to make a decision on what would work best.
In any case, tire pressure and new tires are not going to get rid of your rattles.
For starters, old cars rattle more than new cars. You will never get a 62GT to be as rattle free as a new Toyota.
You can reduce the rattles, however, by carefully and systematically finding what is causing them (there are likely multiple reasons). There is no silver bullet. Each one has a cause that can be anything from a coke can behind a door card to a worn suspension part that was missed during the restoration.
It has always been the case on any extensive restoration I've done that it takes weeks of driving to sort out the squeaks, rattles, and other issues...even when you THINK you addressed everything during the restoration. It's part of the hobby. Finding problems and fixing them.Dick Steinkamp
Bellingham, WA
Originally posted by chet445 View PostI deflated the tires to 28 psi and the car ran a lot smoother not perfect but smoother. I will inflate back up to 35 psi; I need a softer tire I believe. As I stated before the tires are Firestone FR380 P205-75-R15 and were new on the car when I bought it. I have checked a number of places for a softer tire and of course they all want to sell you a set. Hard to make a decision on what would work best.Gary L.
Well I have a "new" '62 Hawk and about 75-80% of the rattles are gone. Gary L suggested I look at the date code on the back of the Firestone tires (new) that were on the car when I bought it and the reading was 10/08. I put 4 new tires on the car with 35 psi and most of the rattles have disappeared, HOORAY!! Now to tackle the low MPG issue.
And l have a '60 Lark Hardtop V8 that l bot 3 years ago and it rattled really badly on the too-large 215 radials it came with. l had the front end components inspected and they were alright. After some thot l ordered new 6.70-15 bias-ply BF Goodrich Silvertowns from Coker.
Wow, what a wonderful difference! My car went from a hard-steering to easy-steering (l have no power steering), the ride is much, much better (running 27 pounds in front and 25 in the rear), and like Chet, a lot of the rattles disappeared. Does the car wander on the road? Only a small amount, easily dealt with while driving - probably no more than when the Lark was new! l'm a "happy camper"!
New tires of the proper size is money well spent!Roger Hill
60 Lark Vlll, hardtop, black/red, Power Kit, 3 spd. - "Juliette"
61 Champ Deluxe, 6, black/red, o/d, long box. - "Jeri"
Junior Wagon - "Junior"
"In the end, dear undertaker,
Ride me in a Studebaker"
Hi Patrick.
Yes, you're right, but l put the pressure up a little more because l'm often running at secondary highway speeds and with stuff in the trunk. Plus 20 pounds just sounds so low!Roger Hill
