Results 1 to 18 of 18
Thread: Champ tailight improvement
    Oct 2010
    770
    As many of you know I am currently repainting our 64 Champ , Anyway while removing the taillight lens I noticed the inside of the bucket was painted black. I am sure if I painted the bucket white or silver it would certainly make the lights more visible , Just a heads up to other Champ owners , Ed
    1,349
    I try to always line the taillite housing with aluminum foil, shiny side out, really helps. Luck Doofus
    Coquitlam, BC, Canada.
    136
    Also use the high intensity LED cluster bulbs which really smarten up the light output.
    From SuperBrightLeds.com
    Centralia, WA, USA
    2,244
    Quote Originally Posted by 007 View Post
    Can these be used without other modifications?
    Don Wilson, Centralia, WA
    40 Champion 4 door*
    50 Champion 2 door*
    53 Commander K Auto*
    53 Commander K overdrive*
    55 President Speedster
    62 GT 4Speed*
    63 Avanti R1
    64 Champ 1/2 ton
    * Formerly owned
    14,205
    White paint is the best; much more reflective than silver, chrome or foil.
    President Member (S)'s Avatar
    Aug 2010
    Ferndale, Washington
    2,080
    Definitely put something besides black in there. I've seen mostly Egg Shell color on the inside of the truck housings. Anything will help.
    Most LED bulbs need an electronic flasher because the points type won't work on such a low draw. Some are built in now for older cars.. There are threads somewhere here about using the LED's
    1,153
    I have this type in my Sky Hawk tail lights, with the Stock flasher...no problems. They're for motorcycle tail lights. And bright white paint DOES reflect more light than anything else...
    136
    No mods are required to operate these LED bulbs. I guess that is a bit of a misnomer since it is not a bulb but a series of L.E.D. (light emitting diode)
    The company (SuperbrightLeds.com) also has an excellent tech department if you have any inquiries about LED's.
    Regards,
    Mark
    Kentucky Bluegrass
    3,085
    For LED, isn't the recommendation to get ones that shine red for the tail lights? I remember seeing somewhere that the whites will make the light appear pink instead of red - or maybe there is a difference between plastic and glass tail light lenses...
    Jan 2011
    40
    what is the stock number?
    4,910
    Is the lamp housing on the truck deep enough to accept the bulb pictured?
    Oct 2010
    Dundee, Oregon
    3,193
    I went to their website and the bulb pictured above appears to be this one: 1157 LED Bulb - Dual Function 18 SMD LED Tower - BAY15D Bulb
    Is this correct?
    I just ordered a pair of these for the taillights on my '61 Champ truck. It appears the same bulb is used in the front turn signals. I am curious how these will look and work. Stay tuned.
    Ed Sallia
    Dundee, OR
    Sol Lucet Omnibus
    Oct 2010
    770
    yes please post your results , Thanks Ed
    28,915
    They show 1157-R18-T-2PK RED Led's, 2 for $11.90 They also have the 27 LED ones.
    They do also recommend the Load Resister Kit RL-650-K for $4.95.
    I am guessing that would only be needed, if you run LED's Front and Rear, which IMHO is never needed!
    Red would be the way to go for Tail Lights.
    They won't tell you the important Length Measurement of the "Bulb" portion, but you can figure it out. The Total Length is 1.64 and the Base is .74, so it is .90
    Oct 2010
    Dundee, Oregon
    3,193
    The new bulbs arrived and I installed them this afternoon. They fit right in and worked great. I put the original incandescent bulbs in the truck just in case but I am very pleased with how bright the new LED bulbs are. And they were not all that expensive - $16.59 including shipping for a 2 pack.
    Ed Sallia
    Dundee, OR
    Sol Lucet Omnibus
    Centralia, WA, USA
    2,244
    So to be sure, is this the one you ordered?
    40 Champion 4 door*
    50 Champion 2 door*
    62 GT 4Speed*
    63 Avanti R1
    64 Champ 1/2 ton
    * Formerly owned
    Oct 2010
    Dundee, Oregon
    3,193
    Quote Originally Posted by ddub View Post
    Yes. That is the bulb. They work really well. Nice and bright and about the same size as the incandescent bulbs they replaced.
    Ed Sallia
    Dundee, OR
    Sol Lucet Omnibus
    Centralia, WA, USA
    2,244
    Thanks, just ordered a pair.
    40 Champion 4 door*
    50 Champion 2 door*
    62 GT 4Speed*
    63 Avanti R1
    64 Champ 1/2 ton
    * Formerly owned
